Using classic Outlook for Windows in business environments
You can put it back. Open options>Advanced and then uncheck the Show Apps in Outlook. Close then reopen and it will be back where you originally had it.
How do I move the Outlook 365 Navigation bar from the left side of the Outlook Window to the bottom of the window? The instructions I have researched do not show anything like what exists on my Outlook 365 program.
My navigation bar moved from the left hand side of the screen to the bottom on its own. How do I move it back to the left?
