How to stop Outlook links being opened in Edge
2023-05-23T05:59:12+00:00
Normally my Outlook links open in my default browser Chrome.
Today they started to open in Edge even though Chrome is still the default browser.
How do I get them to open in Chrome again?
I am using Windows 11 with the Outlook app.
2023-06-25T14:43:42+00:00
This is a new feature in OUTLOOK and has nothing to do with the default apps in the OS settings.
Go to Outlook Options > Advanced > Link Handling > "Open hyperlinks from Outlook in:" > Select "Default Browser".
900+ people found this answer helpful.
83 additional answers
    2023-09-21T07:18:22+00:00
    OUTLOOK has nothing to do with the default apps.
    Very funny. Then just open the link in the OS Default browser by default and don't push me with that freak EDGE.
    2023-09-22T13:56:56+00:00
    Trying to understand why you create an additional setting buried in outlook that doesn't follow the setting I made in systems. Is Edge having a hard time getting usage? This is a serious waste of time for everyone.
    2023-10-04T23:35:03+00:00
    Hi @jaxon7au,
    The detailed steps to perform this task graphically can be found here: How to stop Outlook from opening links in Edge Browser
    2023-10-13T12:48:01+00:00
    I hate you Microsoft, a lot.
    I have disabled this "feature" 2 times already and they keep trying to shove us edge anyway. It re enables again and again.
    The setting is now here
