How to stop Outlook links being opened in Edge
2023-05-23T05:59:12+00:00
Normally my Outlook links open in my default browser Chrome.
Today they started to open in Edge even though Chrome is still the default browser.
How do I get them to open in Chrome again?
I am using Windows 11 with the Outlook app.
2023-06-25T14:43:42+00:00
This is a new feature in OUTLOOK and has nothing to do with the default apps in the OS settings.
Go to Outlook Options > Advanced > Link Handling > "Open hyperlinks from Outlook in:" > Select "Default Browser".
900+ people found this answer helpful.
83 additional answers
    2023-08-27T08:37:42+00:00
    My outlook does not have this under Link Handling. It is under File and Browser Preferences after going to Outlook Options and selecting Advanced.
    This is "thanks" to (due to) Microsoft's inconsistent decision (and also fast-paced changing?). Indeed, in older versions of Outlook in Office 365, eg version 2304, it was really Link Handling:
    2023-08-28T20:57:13+00:00
    Thank you so much!
    2023-08-30T20:05:16+00:00
    Thank you so much for posting this!
    2023-08-31T16:58:52+00:00
    I used to be able to open hyperlinks to pdf documents directly in Adobe. This change has added two steps to that process. Do you know a way to keep hyperlinks from opening in any browser?
