How do I move Outlook sidebar to bottom (again!!!)
2022-12-10T17:42:43+00:00
I thought this had been fixed in an update, but it's back again. The bar containing icons for Mail, Calendar, People etc etc is again on the left side at the top instead of at the bottom under the folder display. Surely there must be an easy way to move it to the bottom again ............. please???
2022-12-12T17:47:37+00:00
Try this -
The solution that worked for me was open Outlook, then
  File, Options, Advanced, then uncheck the 'show apps in Outlook' box.
 Save
 Close Outlook then re-open - Bingo
2400+ people found this answer helpful.
65 additional answers
    2022-12-10T18:50:12+00:00
    Hi Abdullah,
    Thanks for your suggestions, but they did not work.
    The Folder Pane is already at normal - I changed it away from Normal then back again, but no change when I reloaded Outlook, and I no longer have the 'Coming soon' indicator (it used to be there but has long been gone). Please see below what I have there now. Any other suggestions will be gratefully received.
    Alfonso
    2022-12-10T18:31:17+00:00
    Hello Alfonsow! My name is Abdullah, and I will assist you today.
    Please follow the steps below:
    1. Open Outlook.
    2. Select "View" > "Folder Pane" then change to "Normal".
    3. Restart the Outlook and check.
    If the above didn't work, please check the below:
    On the upper right corner, you should be able to see "Coming soon", please toggle it off and restart your Outlook. I have attached a picture of it in this message.
    Please let me know if the above steps helped you. Thank you.
    Best,
    Abdullah
    Give back to the Community. Help the next person who has this issue by indicating if this reply solved your problem. Click Yes or No below.
