Hi Karl,
I don’t quite understand the two systems and how they work. I thought That Google switched on 2FA as default when they made changes in June. Certainly my old O’2010 POP login ceased working saying that it could not get password to work. At the same time Google sent a warning the Outlook versions prior to 2013 version would no longer work with their login.
So, when I say ‘wizard’ (an old MS term in office I know) I mean that I went into Gmail and told it I was going to connect with an MS product (I am sorry I can’t recall how I did that, maybe it gave me a password…. My mind is a fog on that) as there was no application pairing on my Gmail account. Then I used the create account feature but did Not use the manual setup. I say this because I cannot explain why my Gmail account was not showing 2FA as switched on (in the image I uploaded) either that or it is a redundant setting in my Gmail account, I just don’t know or understand it.
My guess is that by not using manual setup in Outlook, the process defaulted to IMAP hence it created the .ost files and I didn’t get to choose using the existing data file. I feel, really stupid now that I simply can’t remember the missing detail.
If creating a new ‘profile’ does not create a .pst then I am assuming the ‘profile’(s) is/are stored in another Outlook system file or as a dreaded Windows registry entry set.
Based on where we are, the idea of creating a new profile is to fix any cross/corruption in the existing profile that is preventing embedded email images downloading. Certainly the profile I have ‘was’ set not to download embedded images as a default when I was accessing via POP account settings. Perhaps the O’2019 process has corrupted the original profile in some way. Quite why toggling the settings to restore the download on images does not fix it can only be explained as a ‘bug’ in the package at this point. There have been many posts with users suffering the problem but as yet I have never read one with a solution.
I will have a go at; saving my current .pst as a backup, delete the Gmail App pairing in my Gmail account, create a new outlook profile and then reset up access to Gmail using the new outlook profile. Ideally, If it works, I can use my existing .pst file and get things to work into that.
I have somehow stay calm doing it. I am not doing it tonight but when I have I’ll let you know if it works or if it means I have to go nuclear…. Hope not.
Thank you so much for your patience and help Karl.
Phil
