Outlook 2016 repeatedly asking for Password for gmail account
2022-10-03T04:14:03+00:00
Today, I've had to clean re-install Windows 10 and, therefore, also had to re-install Office 2016.
Everything is working fine except that I can't configure Outlook to retrieve emails from my gmail account and have been browsing/searching the subject for hours.
Have had the same problem a few times before and solved it by changing the following gmail settings:
(i) to accept "less secure apps" (which option, by the way, is no longer available),
(ii) turn off "2-step verification".
Those settings have not been changed since, but Outlook is repeatedly asking for a password and I can't set up the account. I get the same result if I let Outlook configure the account or if I do it manually using the settings from the gmail page or via the mail link in Control Panel.
Have also checked that Microsoft apps & services has been given access to gmail.
The only new thing I found was this: https://accounts.google.com/DisplayUnlockCaptcha and I confirmed.
Question: Is this a Microsoft problem or a gmail problem . . . each not trusting the other's security?
Anyway, whichever it is, I would be most grateful for suggestions.
Many thanks in advance.
2022-10-03T05:04:36+00:00
Hello JohnTCI
Hi, I'm Karl and will be happy to help you today.
What you need to do is enable 2 factor authentications on your Gmail account and then generate an <App Password> to be used as the password or the email account in Outlook. This is a Google change that took effect June 1, 2022
Recap of steps
#1 - enable 2 factor authentication for the GMail account
Turn on 2-Step Verification
https://support.google.com/accounts/answer/1858...
#2 - generate a Google <App Password> for this account (do not turn off 2FA fter generating the <App Password>)
Sign in with App Passwords
https://support.google.com/mail/answer/185833?h...
#3 - Change the password in Outlook for the email account to use the <App Password> you generated in step #2 (suggest using copy ;n paste - the <App Password> is a contiguous 16 character string - no spaces)
*** for an account already configured in Outlook, to change the email account password
#4 - press CTRL+ALT+S to bring up the Send / Receive dialog
#5 - Select the <Group> (most people only have one) --> click on ,<Edit>
#6 - Select the GMail account --> click on <Account Properties>
#7 - paste the <App Password> for the email account password
56 additional answers
    2022-10-03T19:18:16+00:00
    Karl,
    Thank you for that 'nugget' of information I have copied it to a rtf file in case I summon the courage to wipe my Laptop and reintstall everything. I am anything but confident of doing that as I don't know if using windows 10 reset and reinstall will force windows 11 (which I don't want) or that I can actually work out how to re-install Office Pro 2019 even though it would be on the same PC because WIndows installs change all the PC name etc. and there is nothing that tells old folk like me that what to do. So it risk finding that as I've installed it once before I can't install it again even on the same machine. And that would be before trying to sort out how to get the re-install to talk to Gmail..... :(
    I have to say that the systems deployed these days are not at all friendly for older people and with no reliable route for support it is becoming more and more ageist and excluding more people from doing anything, even if it was intended to be 'safer'.
    Thank you again. I am glad John got a solution.
  2. Karl Timmermans 3,685 Reputation points Volunteer Moderator
    2022-10-03T19:56:44+00:00
    Karl,
    Going the nuclear route (wiping your PC) would be extreme and unnecessary if the only reason is related to Outlook.
    Another tidbit you should be aware of is that when you uninstall Office, the Outlook profiles are not removed so when you reinstall Office, Outlook will continue to use the same Outlook profile - hence making the whole exercise a waste of time if the objective is to start over with Outlook.
    As a FYI - how to "start over" with Outlook, would be to use the Control Panel Mail app
    a) - With Outlook closed open the Control Panel app
    Just in case you need info regarding how to access the Control Panel Mail app, that's described in the following article by Outlook MVP Diane Poremsky
    Where is the Control Panel Mail icon?
    https://www.slipstick.com/how-to-outlook/where-is-the-mail-icon/
    If using Windows 11
    How to Open Control Panel in Windows 11
    https://www.lifewire.com/open-control-panel-in-windows-11-5193187
    b) - Select <Show Profile> --> <Add> ---> give the new profile a name (no need to remove the existing Outlook profile)
    c) - Configure your email account(s)
    d) - Set the newly created Outlook profile as the default for the next time Outlook is opened otherwise it'll use the old profile
    In reference to reinstalling Office '2019 (any current version of Office - '2013 and later)
    Office is associated with a Microsoft Account. To download / install Office again, that's done by
    #1 - Log into the applicable Microsoft Account --> click on <Services & Subscriptions>
    #2 - Download and install
    This link will get you there
    Microsoft account | Services & subscriptions
    For perpetual (one time purchase) license (any version of Office designated as <Office 20##>, if you encounter an activation error, would need to follow the steps contained in the following article under the section
    <Activate after reinstalling or moving Office>
    Activate Office using the Activation wizard
    https://support.office.com/en-us/article/activate-office-using-the-activation-wizard-1144e0de-e849-496e-8e33-ed6fb1b34202?ui=en-US&rs=en-001&ad=US#bkmk_phone
    2022-10-04T12:55:54+00:00
    Karl,
    Thank you very much for your kind and informative reply. I followed the instruction to find the ‘old fashioned’ windows control panel in windows 10 and could find an entry for
    Mail (Microsoft Outlook) (32-bit)
    I could open that and it gave a number of options.
    Under Profiles it only has one ‘Outlook’ showing on a General tab
    Under accounts it has 1 showing setup as my email and IMAP/SMTP (send from this email by default)
    Under Data Files it has 2 entries one as my email address in AppData\Local\Microsoft\Outlook*emailaddress.ost*. And the old Outlook 2010 entry called Outlook Data File in Users*username*\Documents\Outlook Files\Outlook.pst
    The old Outlook.pst is what I kept as it retains my email history sent and received and I have been moving the gmail I received into those folders to try and retain that history. However, no emails with images attached/embedded download with the images anymore. Nothing I have tried has fixed that. Those attempts have been repair settings in outlook, checking and cycling the Outlook Trust Center settings to download images. I also tried Using SFC.Exe to repair system files and from the Apps section of windows 10 settings the Modify and Repair feature for MS Office.
    If I cycle a synchronisation with Gmail, sadly I cannot retry getting any emails downloaded if they don’t first arrive with the images, even though I leave copies on the server. At least I know of no way to get them again.
    I didn’t mean to Hijack Johns request for help. I had started a request here
    https://answers.microsoft.com/en-us/outlook\_com/forum/all/outlook-2019-pro-on-windows-10-how-to-fix-corrupt/5a6456db-4db2-4677-b164-3228afc6eeef
    The person replying is sadly confusing me and contradicting what he advised back in June when I tried to fix things when it all went wrong. It’s taken months to pluck up courage to try again.
    I am not sure what to do, the nuclear route as you called it does seem extreme and would take ages as well as the fact it may not workout if I hit more problems that I can’t resolve. So I am apprehensive of trying it.
    Thank you so much for you helpful pointers.
  4. Karl Timmermans 3,685 Reputation points Volunteer Moderator
    2022-10-04T13:57:20+00:00
    Have read through your other thread so let's start from the beginning so that we are both on the same page as tp what the exact issue is that you are trying to resolve today. Also, please indicate whether or not you have created a new Outlook profile at any point in your trouble-shooting process
    Other comments
    #1 - If you uninstalled '2010 after installing '2019 then would definitely recommend doing a <Online Repair> of '2019 just to make sure that everything is set correctly
    <Settings> --> <Apps> --> <Apps & Features> --> scroll down to <Microsoft Office 2019> --> select <Modify> -->Online Install>
    The <online repair> is actually an uninstall / reinstall of '2019. If for any reason the reinstall does not complete which sometimes happen in rare cases, the solution is to log into the Microsoft Account --> click on <Services & Subscriptions> --> download / install. This link will get you there
    Microsoft account | Services & subscriptionsggest
    #2 - As for the nuclear option, wouldn't be something I would suggest from everything I've read to date. Would be a painful and needless exercise that likely would not resolve anything that couldn't otherwise be fixed.
    #3 - Regarding
    Can you expand a little on that? Specifically, (1) is this account configured as a POP or IMAP account and (2) not clear about "cannot retry getting any emails downloaded?
    To confirm how your account is configured, from within Outlook, go to
    <File> --> <Account Settings> --> <Email> tab
    Once the above info is provided, will go from there
