WHY SHOULD WE HAVE TO CHANGE TO THE READING PANE WHICH AT LEAST IS AN OPTION!!!. There have been sooo many complaints about this change they need to change it back. Last time I checked we are the CUSTOMER!
Please see earlier post and please, please also post your dislike for this change here or else the parties responsible will not see this thread and we will have to continue to live with this. By using the "reading pane" you are also opening email that you would otherwise you would just delete, such as "spam". To my of way of thinking this is not a fix nor an option that I wish to use. They just need to listen to the users and change it back. This has been going on for over a week.
Please, Please post your complaints regarding this subject as follows, posted to the thread on 5/17/22
"If everyone on this post can please use the feedback option in Outlook.com (click the "?" at the top right and in the window that opens click the small "Feedback" link at the bottom) to send feedback to Microsoft on this - as with anything the more noise from people the more chance of action.
Their own info in the settings for Quick Actions still says that they appear after both the sender name and the subject line!"
OR
hope they will take note and either change it back or allow us to customize!
There is anther option for feedback that I mentioned as a follow-up to my original post - wanted to repeat it knowing it may be missed in what is now a lengthy thread:
In addition to the using the ? and Feedback route, there is also a separate Microsoft Feedback portal.
- Link to submit your own feedback there:https://feedbackportal.microsoft.com/feedback/or if you'd like to "upvote" what I submitted there:https://feedbackportal.microsoft.com/feedback/idea/9a913ff0-4acf-ec11-a81b-000d3a00c008
