Using classic Outlook for Windows in business environments
Hello ! I'm sorry that you are experiencing this issue, and I am hopeful that I will be able to help you find a satisfactory solution.
Have you check if your outlook app is upto date?
Kindly update your laptop and your app to the latest version and let's see if the issue will continue.
Nelson...
