Problems when using contractions such as I'm, I'll, etc. Any help?
2012-07-04T04:34:34+00:00
I'm having a problem whenever I try to use contractions that begin with "I" - such as I'm, I'll, etc. When I type "I'm", I get "I'  M" followed by a beep. Same thing with "I'll" - Outlook will type it as "I' L" and beep, not allowing me to enter any new characters until I delete the old and I have to type "I am" or "I will". "I've" is also a problem. It's seems as if the auto spell checker is just choking on any contraction beginning with "I"?
Yes, I am running the latest developer version of Mountain Lion but I've been running it for months with no problems in any Office app. This is something new and totally off the wall.
Any suggestions?
Clinton
2012-07-28T04:59:25+00:00
Final update:
Update to Mavericks to resolve this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started.  The fix was released recently in the version of webkit included with Mavericks.
As a temporary workaround please turn off the "Capitalize first letter of sentences" autocorrect setting.
Select the menu Outlook, Preferences, Autocorrect and uncheck "Capitalize first letter of sentences".
Update:
The recent Mac Office 14.2.5 release did not contain a fix for this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started and we are eagerly waiting on a fix.
Apple released version 6.0.2 of Safari early November 2012, including a webkit update.  It is that update which is causing people to see changed, but not fixed, behavior.
The particular test case I have been using to reproduce the problem still fails with Safari 6.0.2.  Other uses are reporting that situations which were broken before now work.
There is no benefit in trying new identities or new user accounts.  The issue is well understood as being a webkit regression from when Mountain Lion was released.  It is not related to any problem with your identity, account or installation.
The above temporary workaround is still the only solution to suppress the problem until a complete webkit fix is released.  Updating to Safari 6.0.2 through Apple Software update may address some situations.
90 additional answers
    2012-08-17T09:46:55+00:00
    Thanks for responding - for some reason I wasn't receiving any email notifications.
    Note that I am only having this problem when using PLAIN TEXT to respond to other users who send me plain text messages. It happens only on replies for me (but then I seldom compose a message in plain text any longer).
    All of my auto-correct boxes are ticked - I'm such a poor typist that I need the help!
    I'll read down the list to see if anyone has a 'fix' yet.
    Clinton
    2012-08-16T19:05:08+00:00
    For me, it appears more when replying to plain text emails as opposed to rich text or html emails
    2012-08-15T13:23:24+00:00
    Add a bit of info from my experience.
    I'm having the same issue for last 3 weeks or so... once it starts happening in an email, i cannot seem to shake it, but it's not all of the time.  I have 4 emails open right now, and 3 are fine, one is an issue.
    It doesn't seem to matter if its HTML or Plain, but if i toggle them back and forth in the 'options', sometimes the issue goes away, other times it just messes up my email formatting in odd ways.
    I tried running numerous antivirus and spyware software in case this was some kind of nuisance bug i picked up, but no luck there either.
    The only words i see an issue with are I'll, I've and I'm - result in I'Ll, I'Ve, and I'M.  I only see it in Outlook though, not Word, although I dont use Word very often.
    OSX 10.8, Outlook 14.2.3
    I sure hope someone can find a way to prevent this.
    2012-08-15T00:59:07+00:00
    Yep we're having the same problem too on a computer which upgraded to Lion with Office 2011 already installed AND a computer that had a clean install of Lion and installed Office 2011 thereafter.
    The word....
    I'm
    ....seems to cause the most grief, and doesn't matter if its text or html emails.
    No special fonts. And yes all AutoCorrect preferences were at their default "on" position" (we have since turned auto-capitalisation off as per your suggested workaround below....but obviously we miss having that feature!).
