Problems when using contractions such as I'm, I'll, etc. Any help?
2012-07-04T04:34:34+00:00
I'm having a problem whenever I try to use contractions that begin with "I" - such as I'm, I'll, etc. When I type "I'm", I get "I'  M" followed by a beep. Same thing with "I'll" - Outlook will type it as "I' L" and beep, not allowing me to enter any new characters until I delete the old and I have to type "I am" or "I will". "I've" is also a problem. It's seems as if the auto spell checker is just choking on any contraction beginning with "I"?
Yes, I am running the latest developer version of Mountain Lion but I've been running it for months with no problems in any Office app. This is something new and totally off the wall.
Any suggestions?
Clinton
2012-07-28T04:59:25+00:00
Final update:
Update to Mavericks to resolve this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started.  The fix was released recently in the version of webkit included with Mavericks.
As a temporary workaround please turn off the "Capitalize first letter of sentences" autocorrect setting.
Select the menu Outlook, Preferences, Autocorrect and uncheck "Capitalize first letter of sentences".
Update:
The recent Mac Office 14.2.5 release did not contain a fix for this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started and we are eagerly waiting on a fix.
Apple released version 6.0.2 of Safari early November 2012, including a webkit update.  It is that update which is causing people to see changed, but not fixed, behavior.
The particular test case I have been using to reproduce the problem still fails with Safari 6.0.2.  Other uses are reporting that situations which were broken before now work.
There is no benefit in trying new identities or new user accounts.  The issue is well understood as being a webkit regression from when Mountain Lion was released.  It is not related to any problem with your identity, account or installation.
The above temporary workaround is still the only solution to suppress the problem until a complete webkit fix is released.  Updating to Safari 6.0.2 through Apple Software update may address some situations.
90 additional answers
    2014-04-03T09:48:57+00:00
    Not all of us have or even want to update to Mavericks, the fix should be implemented to previous versions as well.
    2013-12-16T20:26:39+00:00
    It seems to only happen with plain text and only when the message starts out as plain text. If your default message format is HTML and then switch to plain text, you will not encounter the problem.
    You'll also see this if your default message format is HTML, but also have the "When replying or forwarding, use the format of the original message" preference checked and the message you are replying to or forwarding is plain text.
    Unchecking the "Capitalize first letter of sentences" preference works around this problem for now.
    Can't upgrade to Mavericks because of some proprietary software that is incompatible.
    In Mountain Lion OS X 10.8.5, using Outlook for Mac 2011 (14.3.9), the I'M I'Ll I'Ve I'D capitalization errors don't seem to happen when I compose a new message in text format, or if I switch option to HTML and back to Text. It only arises if my Composing options are set to "When replying or forwarding, use the format of the original message" and I reply-to/forward an email written in text format.
    My workaround: in Preferences > Composing, I
    * selected "Compose messages in HTML by default" AND
    * deselected "When replying or forwarding, use the format of the original message"
    More info here: http://arstechnica.com/civis/viewtopic.php?f=19&t=1180706
    2013-11-25T19:29:55+00:00
    Mavericks does indeed seem to resolved the issue.  However I’m noticing an odd though less problematic fluke.  With the auto-correct function “capitalize first letters of sentences” re-activated (I had de-activated it as a workaround for the original problem), if the first word of a sentence contains an apostrophe, the auto-correct won’t work and won’t automatically capitalize the first letter of the word.
    2013-11-25T19:17:26+00:00
    Hm. i understand the rationale, mavericks is a free update.
    unfortunately my up-to-date machine needs quality font management for my trade, and so upgrade is not yet possible.
    Also my older machine is no longer able to update to the latest OS.
    This should be patched by MS. but hey, at least the reply button works again.
