Problems when using contractions such as I'm, I'll, etc. Any help?
2012-07-04T04:34:34+00:00
I'm having a problem whenever I try to use contractions that begin with "I" - such as I'm, I'll, etc. When I type "I'm", I get "I'  M" followed by a beep. Same thing with "I'll" - Outlook will type it as "I' L" and beep, not allowing me to enter any new characters until I delete the old and I have to type "I am" or "I will". "I've" is also a problem. It's seems as if the auto spell checker is just choking on any contraction beginning with "I"?
Yes, I am running the latest developer version of Mountain Lion but I've been running it for months with no problems in any Office app. This is something new and totally off the wall.
Any suggestions?
Clinton
2012-07-28T04:59:25+00:00
Final update:
Update to Mavericks to resolve this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started.  The fix was released recently in the version of webkit included with Mavericks.
As a temporary workaround please turn off the "Capitalize first letter of sentences" autocorrect setting.
Select the menu Outlook, Preferences, Autocorrect and uncheck "Capitalize first letter of sentences".
Update:
The recent Mac Office 14.2.5 release did not contain a fix for this issue.
The problem is related to webkit.  Webkit is a component of OS X (it is the HTML rendering engine behind Safari).  The bug was reported to Apple shortly after this thread started and we are eagerly waiting on a fix.
Apple released version 6.0.2 of Safari early November 2012, including a webkit update.  It is that update which is causing people to see changed, but not fixed, behavior.
The particular test case I have been using to reproduce the problem still fails with Safari 6.0.2.  Other uses are reporting that situations which were broken before now work.
There is no benefit in trying new identities or new user accounts.  The issue is well understood as being a webkit regression from when Mountain Lion was released.  It is not related to any problem with your identity, account or installation.
The above temporary workaround is still the only solution to suppress the problem until a complete webkit fix is released.  Updating to Safari 6.0.2 through Apple Software update may address some situations.
90 additional answers
    2013-09-12T20:21:16+00:00
    Only Microsoft can give you a real solution. We are users just like you.
    http://www.microsoft.com/mac/product-feedback
    2013-09-12T14:43:32+00:00
    This is absolutely insane. Every time I attempt to type I'm it gets changed to I'M. Tried the solution in Autocorrect settings, but when I try to enter the apostrophe as an exception, it automatically adds a period to the end and doesn't work!!!!
    You've got to be kidding me, right? A contraction as common as "I'm" is not recognized?!
    Please give us a real solution, not a work around.
    This is way too common and obvious to not have been addressed.
    2013-07-18T19:43:41+00:00
    I've found a way that fixes this issue and keeps the "Capitalize first letter of sentences" autocorrect setting turned on. It does however cripple Safari's autocorrect feature, fortunately I don't use Safari.
    Open Safari
    Click in a text field, for example the search box at bing.com
    Click "Edit" in the Menu Bar
    Expand Spelling and Grammar"
    Uncheck "Correct Spelling Automatically"
    Quit Safari
    Test out a new email and notice that Autocorrect still works, but it does not change I'll to I'Ll
    2013-07-18T15:14:30+00:00
    Was a proper solution ever made? I still suffer from this problem and find the temporary fix unacceptable.
    Nope - I thought that an update might fix the problem but, thus far, none have.
    Clinton
