"Silent" Notification Doesn't Work On Outlook.com Android App
2013-07-09T14:40:29+00:00
Downloaded and configured the Outlook.com app for my HTC One and it will play any audible notification that I select except for "Silent".
settings > General > Notifications > Email Notifications > Audio Notification
If I do select "Silent", it still plays an audible tone - a tone unique to the application. It doesn't sound like any other selectable tone.
Even if I uncheck notifications, the tone still plays.
I really like the application, but I can't use it if it refuses to be silent on each new email :)
2013-10-29T02:20:40+00:00
Hi LMFPeach and FlipmodeMF,
Thank you for getting back to us. Since the option to turn the sounds off on Outlook.com app does not work, then there is a possibility that the Outlook.com app itself is causing this issue. It might be that the Outlook.com app is faulty.
Now, we recommend that you uninstall the Outlook.com app and download the latest version of it from the Play store. Once done, we recommend that you turn the email notification sound off by following the steps below:
1.       Open the Outlook.com app on your mobile device.
2.       Tap on the Menu option.
3.       Tap on Settings.
4.       Choose General.
5.       Choose notifications.
6.       Click on email notifications and then make sure that the box is unchecked.
7.       Tap on Audio Notification.
8.       When you get into your notification, choose the "silent" button.
Let us know how things turn out. Feel free to post back if you have further questions.
Regards,
Johayber T.
62 additional answers
    2013-08-10T23:47:10+00:00
    Hi MikeWatrous and LMFPeach,
    Welcome to Microsoft Community. We understand your concern about Silent Notification not working on Outlook.com app. Let me assist you with this.
    As an initial troubleshooting step, please try to uninstall and then reinstall the Outlook.com app on your mobile device as what my colleague Levi_I mentioned above. There might be some corrupted files that are causing the problem to happen.
    If you are still encountering this issue, please provide the following information in the private message area for further investigation.
    • Affected email address
    • Does the same issue happen if you use another account on your device?
    • What is the device make/model and version of operating system? (only for MikeWatrous)
    • Exact steps that you did in changing your Sound settings.
    I have created a private message area where you can provide the needed information.
    You may refer to the private message tab or you need to click the notification that states “You have a private reply to this message. Click here to read it on our secure private messages section.", be sure that you are signed in to view my message.
    We are looking forward to your response.
    Regards,
    Grace
    2013-08-20T19:25:38+00:00
    Hello! I have the same problem.
    I am running Android 4.1.2 on a Galaxy Samsung S 2.
    Global phone settings for notifications are set to silent. All Notification settings for the Outlook e-mail on my phone disabled. The app continues to play the 'postman' sound every time I receive an e-mail. ONLY happens with outlook exchange e-mail. Doesn't happen with G-mail or text messages that I receive.
    I have tried changing the sound, and the same 'postman' sound continues to play.
    It seems that many other users are having the same issue.
    2013-08-20T20:44:18+00:00
    I have found a way to make the app silent, although no notifications show in the status bar either.
    I uninstalled the app. Then, when I was in the process of re-installing it, I unchecked the box for "deliver notifications". So far, the app has been silent. However, when I go to "general settings" and turn on sound, vibration or status bar notifications, nothing changes--It remains silent.
    I would prefer to have it permanently silent with no notifications though, than to have it making that annoying dinging sound!
    Hope this helps!
    2013-10-21T08:45:28+00:00
    I have same issue. Wakes me at night when I receive mail. Defect not corrupt data in my opinion. Too many people reporting identical issue.
