"Silent" Notification Doesn't Work On Outlook.com Android App
2013-07-09T14:40:29+00:00
Downloaded and configured the Outlook.com app for my HTC One and it will play any audible notification that I select except for "Silent".
settings > General > Notifications > Email Notifications > Audio Notification
If I do select "Silent", it still plays an audible tone - a tone unique to the application. It doesn't sound like any other selectable tone.
Even if I uncheck notifications, the tone still plays.
I really like the application, but I can't use it if it refuses to be silent on each new email :)
2013-10-29T02:20:40+00:00
Hi LMFPeach and FlipmodeMF,
Thank you for getting back to us. Since the option to turn the sounds off on Outlook.com app does not work, then there is a possibility that the Outlook.com app itself is causing this issue. It might be that the Outlook.com app is faulty.
Now, we recommend that you uninstall the Outlook.com app and download the latest version of it from the Play store. Once done, we recommend that you turn the email notification sound off by following the steps below:
1.       Open the Outlook.com app on your mobile device.
2.       Tap on the Menu option.
3.       Tap on Settings.
4.       Choose General.
5.       Choose notifications.
6.       Click on email notifications and then make sure that the box is unchecked.
7.       Tap on Audio Notification.
8.       When you get into your notification, choose the "silent" button.
Let us know how things turn out. Feel free to post back if you have further questions.
Regards,
Johayber T.
62 additional answers
    2013-07-10T12:25:58+00:00
    Hi rmuser,
    We appreciate your time in posting here in the Microsoft Community. We understand your concern on the Silent Notification not working on Outlook.com app.
    For us to isolate application as possible cause of issue, please try reinstalling the said app and see if issue will persist. Please also adjust the "Sound" settings of your phone. There should be an option there to change or turn off the sound alerts of the said notifications.
    Let us know how things turn out!
    Thank you.
    I have uninstalled and reinstalled twice - no change.
    I do not want to disable sound in all notifications, only disable the sound for new emails. I am a new Android user and have tried many email applications over the last few days. The Outlook.com application is the only one that continues to play a notification sound even after it has been set not to do so. It is definitely a bug in the app :-)
    Thanks.
    2013-07-10T07:32:44+00:00
    Hi rmuser,
    Thank you.
