Managing sound and video settings during Teams meetings and calls for optimal communication
Same issue here!!
Hi all, I have a strange issue when using an external display (Dell S2721DS connected via USB-C to HDMI cable) on an iPad Pro M1 11".
If Teams is on the external display (extended, not mirrored), my outgoing video is rotated 90 degrees so I appear sideways to others in the call. When I move the Teams app to the iPad display it reverts back to the correct orientation.
This is also happening with Zoom, but not FaceTime. Can anyone else replicate this behaviour, or does anyone know a fix for it?
Same issue here!!
Same problem here (tested today with iPad Pro M1 11 inch 2024): camera is 90 degrees tilted and external camera not supported.
No - it doesn’t work. still the same behaviour.
Still the issue with my ipad 11’ M4
You simply cannot use Teams with an external monitor if you want to make a videocall in 2024…
Same issue
iPad M4 pro
