Managing sound and video settings during Teams meetings and calls for optimal communication
Hola,
Thank you very much for your answer, it saved my teams life !!!!!!!!
I have tried everything, and I have boiled the issue down to Teams. A user has been having issue when on Teams they cannot hear anyone. No matter what they do there is no sound. Thier laptop speakers work perfectly fine in 10 different applications (Google Meet, Zoom, Chrome, Firefox...) Teams is the ONLY application that can't seem to use the speakers. I have tried reinstalling the audio driver from both Dell and form the manufacture with no change. I have tried removing all other sound devices then it, same issue. I have tried making it the default communication device, same issue. I have tried using headphones plugged into the 3.5mm jack, same issue. The only thing I can boil it down to is Teams. I have no idea what Teams does to audio, but this is not the first time it's been a Teams issue. I have a pair of Jaybird Vista Bluetooth headphones, and they cause teams to bluescreen. Been using them for 3+ years no issues on 3 different laptops. We move to Teams, bluescreens every day. Stop using them low and behold the bluescreens stop happening. Call MS support and I get told to use another pair there is obviously something wrong with mine (the pair that has been working perfect for 3+ years) I also tried them on a new machine, same issue, blue screen.
Any ideas of what to check next for this audio issue? Users can't do any meetings because they can't hear anyone. They have to use their phone to join meetings with audio which is really annoying for the user.
Hola,
Oh my goodness thank you!!!! Been dealing with this for weeks and this is the only solution that has worked
A few weeks ago my speakers stopped working in both zoom and teams meetings. I have tried this and also asked an IT person to help me. Nothing works. Any other ideas? It’s so frustrating.
Go into your Sound Control Panel and start turning features on and off and keep testing after each change. And I mean the OLD sound control panel. Go to control panel not windows settings. After each test turn the setting back. Trial and error to be honest is the only way! Also check your sound equalizer, some people turn down the mixer for just a single app.
Another option is to make sure audio driver is up to date from laptop manufacturer and if that does not work go right to the maker of the sound card. If that does not work roll back to the laptop manufacturer driver.
I am assuming it works with no issues with anything else?
