Managing sound and video settings during Teams meetings and calls for optimal communication
Also i beleive this started for me after Installing Color OS 13 Beta
On Android, all of a sudden, Teams repeatedly says, "Teams Needs Permission" "If you want to place a call or join a meeting, go to settings and allow Phone permission to Teams."
It then takes you to Android Settings for the Teams app, and the "phone" permission IS allowed.
I've rebooted.
Cleared cache.
Cleared data
Reset the database.
Left developer preview.
Reinstalled Teams
Left the Beta and done all of the above over and over.
It isn't honoring the permissions that are set. So I can't join any meetings. Please advise.
When will this be fixed? I can no longer leave the office when I have meetings, how is still not fixed?
This worked for me on my Galaxy S10. Nothing else that has been suggested did. Ended up with version 1416/1.0.0.2022233101/0210 Thanks
Like others posted, I removed my teams Beta enrollment, uninstalled it, waited for about 2 hrs, reinstalled from Play Store and it works. No issues...
same problem here with my samsung tab s8 ultra
