Keeps asking for Phone Permissions to join meetings
2022-11-03T14:20:44+00:00
On Android, all of a sudden, Teams repeatedly says, "Teams Needs Permission" "If you want to place a call or join a meeting, go to settings and allow Phone permission to Teams."
It then takes you to Android Settings for the Teams app, and the "phone" permission IS allowed.
I've rebooted.
Cleared cache.
Cleared data
Reset the database.
Left developer preview.
Reinstalled Teams
Left the Beta and done all of the above over and over.
It isn't honoring the permissions that are set. So I can't join any meetings. Please advise.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
    2022-11-10T20:00:13+00:00
    Same issue here. Just started today. I've reinstalled, cleared cache, cleared data, removed and re-added all permissions. No effect. Samsung s22 ultra...
    2022-11-10T20:12:49+00:00
    Absolutely correct. Issue within the beta current beta. Opting out, deinstalling and then installing the regular version from the store will fix this.
    2022-11-10T20:23:13+00:00
    Try this
    1. Leave beta from playstore
    2. Uninstall Teams
    3. Install Teams from Galaxy store & NOT playstore (Very important)
    Lower version that on playstore now should be installed on your phone.
    PS - I first tried to install regular version from playstore but the issue still persisted, hence had to go via Galaxy store route
    2022-11-11T04:53:36+00:00
    Same to me... Note 9 and S22 Ultra neither works
    2022-11-11T04:58:06+00:00
    You save my day!!! It works perfectly!!! Thank you. I uninstalled The teams (Beta) and then installed from Galaxy Store and runs smoothly and perfect!! Thanks again!!
