Managing sound and video settings during Teams meetings and calls for optimal communication
I'm having the same problem... Any resolution on this?
On Android, all of a sudden, Teams repeatedly says, "Teams Needs Permission" "If you want to place a call or join a meeting, go to settings and allow Phone permission to Teams."
It then takes you to Android Settings for the Teams app, and the "phone" permission IS allowed.
I've rebooted.
Cleared cache.
Cleared data
Reset the database.
Left developer preview.
Reinstalled Teams
Left the Beta and done all of the above over and over.
It isn't honoring the permissions that are set. So I can't join any meetings. Please advise.
Looking at https://www.apkmirror.com/?post\_type=app\_release&searchtype=apk&s=Microsoft+Teams, it seems that the broken version 412701 is the latest beta and the working version 395202 is the latest stable.
That's the danger of being in the beta. Sometimes things break. If you rely on it for work, might be a good idea to switch back for now.
I have the same issue, Pixel 7 pro. Can't join meeting or make calls.
I moved out of beta as per the steps listed above and it worked
