Managing sound and video settings during Teams meetings and calls for optimal communication
you can try: clear cache, unisntall, delete microsoft account from android accounts settings, reinstall, voilà
On Android, all of a sudden, Teams repeatedly says, "Teams Needs Permission" "If you want to place a call or join a meeting, go to settings and allow Phone permission to Teams."
It then takes you to Android Settings for the Teams app, and the "phone" permission IS allowed.
I've rebooted.
Cleared cache.
Cleared data
Reset the database.
Left developer preview.
Reinstalled Teams
Left the Beta and done all of the above over and over.
It isn't honoring the permissions that are set. So I can't join any meetings. Please advise.
Does anybody have tips on how to unenroll from the beta on Android? Looked in the app itself and also in the play store and I don't see any place to enroll or unenroll. I do have the 412701 version so according to your statement here I'm in the beta and just don't know how to leave.
Go to the play store on your device, fInd Teams, scroll down in the app page, there will be a leave beta button.
Hope this helps.
For Samsung users : I had the same problem, I unistall the app (Google Play Store) and install it from the Galaxy Store, and it works.
Finally found it!! Thank you for the help.
