Managing sound and video settings during Teams meetings and calls for optimal communication
Hi Sajjad - I tried this . . . but alas still get the beeping. Thanks for trying anyway.
Hello
I see a lot of threads and people moaning about Double beep when muted on Teams when using a Shokz headset which is the problem I have. (Headset previously called AfterShokz)
I use a work computer so do not have admin rights, and muting shoks headset by pressing the +/- volume keys does not stop the beeping noise.
Any help would be appreciated.
Thank you
Hello all,
There is a solution on Windows, if you are able to install VB-Audio Virtual Cable. The program is for free. You can use following tutorial, which I found in 2021, when Teams always changed the microphone gain. This also helps for the mute issue as you will use a virtual microphone in Teams, which listens to your Shokz Mic. Hence Teams can't interfere with Shokz device anymore. Therfore no Audrey announcement and no beeps.
Here is the link:
https://sysadmin-central.com/2020/08/05/microsoft-teams-fix-auto-adjusting-microphone-audio/
Works for my Aftershokz Aeropex!
I did just try this and it does actually work. The only annoying thing that then happens is Teams no longer shows a highlight around you when you are speaking, or in the mic settings if you talk to yourself, you dont see the audio bar moving. But people could still hear me in a call and the mute beep issue was gone. So as a solution idea I think this is great vs the beep beep issue.
Issue solved. Thanks
This did not work for me.
