Audio not coming through Bluetooth Headset
2023-05-05T14:28:17+00:00
Seemingly randomly, Teams will not output audio through my Bluetooth headset (microphone will consistently work). The only way that I have found to fix it is to restart my computer. This problem is specifically with Teams, system sounds, browser sounds, and Zoom calls will all give audio to the headset, even if teams is not. I am able to see my headset in device settings in Teams and can select it. If I change the audio to output through my laptop speakers, I am able to hear audio.
Some troubleshooting I have tried:
  • Swap around audio devices within Teams
  • Disconnect Headset from laptop
  • Ensure Headset is forgotten from laptop
  • Restart Laptop (This will always fix the issue for an unspecified amount of time
The Bluetooth headset that I am using is Steel Series Artic 9. I can consistently get this headset to work with other Bluetooth devices, such as my personal PC, my wife and my phones, my wife's laptop. So the issue seems to specifically be teams on my work laptop.
Here are 2 examples on when I have seen the issue pop up.
  1. Connected for my first Teams meeting in the morning, audio worked fine. Joined a new meeting 1 hour later and there was no audio. The headset did no disconnect, and was left on until the next meeting.
  2. I put my laptop to sleep when I am not working (been turning it off the past week) when I wake the laptop when I begin work again, the headset will not have audio through teams. This is random as some days it would work and others it would not.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
    2024-07-09T01:29:46+00:00
    I'm having exactly the same issues and it's just started recently. I had a Sony WH-1000XM4 and it's been working (not great) with Teams, there were always 2 options, for my Headseat, one is Stereo and one is Handsfree. The Stereo has been working well until today.
    I've got sounds on everything except Teams (i.e. can watch Youtube on Chrome, listening to Music with different apps... etc)
    I found that after a Teams call with no audio on my Bluetooth headset, and I have to switch to my speakers. Then it seems like I lost windows sound, and I had to switch my sound on the lower right corner icon to my Speakers, then back to my Headphone to have audio back
    I found that iTunes had the same issue routing the audio, when I change its Playback preference to use Direct Sound rather than Windows Audio Sessions, it seems to route the Audio to my Headphone.
    When I change the Sound output option of the speaker icon on the lower right corner, iTunes still play my music on whatever it started on, unless I restarted it
    It seems more likely an issue with Windows 11, or maybe something with Teams (internally they may be trying to blame each other lol).
    Below is my "About Teams"
    VersionYou have Microsoft Teams version 24152.415.2975.367.You've got the latest version. It was last checked on 09/07/2024.The client version is 49/24053101421.
    2024-07-17T15:38:43+00:00
    A few days ago, I got updates to
    1. Teams - 24165.1414.2987.41.
    2. Dell's docking station
    3. Realtek driver 10.0.246.1
    4. Dell's BIOS
    All at the same time.
    Now, everything works great!
    I'm switching back and forth between different headsets (in the past, sometimes it worked with one specific headset), speakers, docking, and nondocking, and it works!
    Really hope that it won't break again.
    2024-07-18T05:52:32+00:00
    Read this post and thought, maybe they're finally fixed this,.. alas, same behaviour, audio/mic works everywhere,.. only mic works in Teams.
    2024-08-29T13:49:50+00:00
    I am going to give that a try. I also have that Intel Bluetooth Audio driver. See if that helps.
    2024-08-29T14:51:03+00:00
    Seeing the positive feedbacks from many people here, I also gave it a new try after somes updates of both Teams application and bluetooth/plantronics drivers.
    I removed the Plantronics USB dongle and paired directly my headset with the integrated bluetooth of my laptop.
    Everything seems to work fine in Teams after 2 week of heavy testing with multiple conf calls every day.
    The versions I have :
    Teams :  24215.1007.3082.1590
    Teams client : 49/24071128825
    Intel bluetooth drivers : 23.40.0.2
    Plantronics Focus driver : 10.0.19041.4597
    Plantronics Focus voyager firmware : v.715
