Teams for Android does not work with Bluetooth.
2022-12-06T00:51:43+00:00
Teams will not recognise Bluetooth headphones when joining calls.
I have tried restarting, clearing cache, clearing storage and reinstalling. I have tried multiple different models of headphones from completely different manufacturers. I have tried different phones.
This is not a user issue. This is an issue with the application. Several posts have been made.
Please fix it.
EDIT: the 'Nearby Devices' permission will fix this issue in most cases. For me, it worked temporarily (for one call) and then reverted to the same issue. However, the issue does now seem to be fixed - I have had consistent success for about 2 months now. I am assuming that a recent update to the app has fixed an issue that was causing this.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
2023-06-14T03:03:30+00:00
Hi Chris,
I had the same problem, and I noticed it was because of the permission setting of TEAMS.
I reinstalled Teams and accepted the "Nearby devices." access and it works now.
Sabrina
90 additional answers
    2023-01-12T19:44:58+00:00
    Confirm it works on Samsung S20+ with latest firmware and MS Teams
    On an Samsung Android:
    -Settings>apps>
    -Click top right ... >Select Permission Manager
    -Nearby devices> Select Teams > Allow
    -Connect to your Bluetooth device
    -Start a teams call
    -Click on the speaker during the call and select the Bluetooth device
    Took me 5 min to change it. Thx a lottttt !
    2023-01-20T08:20:31+00:00
    This is correct answer for me. Apparently there have been some changes in location permissions that are required for Bluetooth in Android 12, and the required changes are not implemented in Teams.
    I opened the application settings inside Android system settings, and allowed the location permission.
    Thanks a lot.
    2023-01-26T14:42:09+00:00
    I was able to fix it by reinstalling the Teams app. After installation it requested additional permissions for Bluetooth device access. Maybe it happened because some android versions tend to remove unused permissions after a while...
    2023-01-30T13:55:18+00:00
    Agree, foolish suggestion. Having same issue. Bluetooth works with EVERY OTHER application but not TEAMS. Clearly, a TEAMS issue
