Teams for Android does not work with Bluetooth.
2022-12-06T00:51:43+00:00
Teams will not recognise Bluetooth headphones when joining calls.
I have tried restarting, clearing cache, clearing storage and reinstalling. I have tried multiple different models of headphones from completely different manufacturers. I have tried different phones.
This is not a user issue. This is an issue with the application. Several posts have been made.
Please fix it.
EDIT: the 'Nearby Devices' permission will fix this issue in most cases. For me, it worked temporarily (for one call) and then reverted to the same issue. However, the issue does now seem to be fixed - I have had consistent success for about 2 months now. I am assuming that a recent update to the app has fixed an issue that was causing this.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
2023-06-14T03:03:30+00:00
Hi Chris,
I had the same problem, and I noticed it was because of the permission setting of TEAMS.
I reinstalled Teams and accepted the "Nearby devices." access and it works now.
Sabrina
90 additional answers
    2023-03-01T06:49:41+00:00
    The issue is just setting up the permissions in Android phone for Teams.
    Steps:
    (1) Give permissions of "Nearby Devices", to App Teams.
    (2) Unpair the Bluetooth you are using for now.
    (3) Restart the phone, and Pair the Bluetooth device you are using
    (4) Now initiate a call over Teams. You should be able to make the call using your connected Bluetooth device.
    2023-03-01T16:06:56+00:00
    Experiencing same issue, where phone is connected to Bluetooth, but Teams only communicates through the device.
    Resolution:
    Teams use of Bluetooth, requires. Permissions to "Nearby Devices".
    Go to app permissions and enable it!!
    Regards,
    Steve
    2023-03-02T20:18:21+00:00
    I just fixed the issue on my phone by enabling app permissions to "nearby devices".
    2023-03-06T21:24:25+00:00
    Dear All,
    I've been experiencing the same issue on Samsung Galaxy S21 recently.
    While following the MS Teams cleanup (cache, data), I noticed that during initial setup MS Teams asked me for "Nearby devices" permission.
    I granted the permission and Teams now work with the Bluetooth headphones.
    To check, I disabled the permission and the symptom was as previously observed - Bluetooth option not listed as available device.
    So, try to grant the "Nearby devices" permission and see if it works.
    Cheers, Jacek
