My Jabra evolve 75 get stuck in call mode after Teams call is ended.
2023-01-31T11:59:26+00:00
It seems Teams cannot end the call on my Jabra Evolve 75 headset appropriately. The Teams call is ended but the headset is left as if still in a call in mono mode.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
Alvaro A- 1,670 Reputation points Independent Advisor
2023-01-31T12:35:23+00:00
Hi Flemming,
I'm sorry to hear that you're have issues with your Jabra whenever you end calls. First, let's make sure that the user's Teams app cache files are not corrupted. Please follow the steps below according to your operating system.
Clear Teams cache in Windows
If Teams is still running, right-click the Teams icon in the taskbar, and then select Quit.
Open the Run dialog box by pressing the Windows logo key +R.
In the Run dialog box, enter %appdata%\Microsoft\Teams, and then select OK.
Delete all files and folders in the %appdata%\Microsoft\Teams directory.
Restart Teams.
Clear Teams cache in macOS
If Teams is still running, right-click the Teams icon in the dock, and then select Quit, or press Command (⌘)-Q.
In the Finder, open the /Applications/Utilities folder, and then double-click Terminal.
Enter the following command, and then press Return:
rm -r ~/Library/Application\ Support/Microsoft/Teams
Restart Teams.
This usually fixes these types of issues but if not, you'll have to make sure that the proper drivers for your Jabra 75 are installed in your PC. You may download it from here.
https://www.apac.jabra.com/supportpages/jabra-e...
69 additional answers
    2024-01-24T09:49:09+00:00
    I'm glad that i found this forum with exactly the problem we are struggling with nearly all of our SLS.
    Another strange "workaround" beside the test call is, to open the Windows Settings app => System => Sound => under Output section click on "Manage sound devices" and close the window (DO NOT go back).
    It then changes to normal audio mode instead of getting stuck in call mode.
    But I may found a POSSIBLE SOLUTION in an Intel article:
    No Audio Output with Intel® Smart Sound Technology Update after...
    Changing the driver of the "Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller" to the "High Definition Audio controller" as described brought the solution for me on 2 of the SLS devices.
    Let's see how long it will last. Maybe the next Firmware Package/Windows Updates are reverting the change back to faulty "Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller".
