My Jabra evolve 75 get stuck in call mode after Teams call is ended.
2023-01-31T11:59:26+00:00
It seems Teams cannot end the call on my Jabra Evolve 75 headset appropriately. The Teams call is ended but the headset is left as if still in a call in mono mode.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
Alvaro A- 1,670 Reputation points Independent Advisor
2023-01-31T12:35:23+00:00
Hi Flemming,
I'm sorry to hear that you're have issues with your Jabra whenever you end calls. First, let's make sure that the user's Teams app cache files are not corrupted. Please follow the steps below according to your operating system.
Clear Teams cache in Windows
If Teams is still running, right-click the Teams icon in the taskbar, and then select Quit.
Open the Run dialog box by pressing the Windows logo key +R.
In the Run dialog box, enter %appdata%\Microsoft\Teams, and then select OK.
Delete all files and folders in the %appdata%\Microsoft\Teams directory.
Restart Teams.
Clear Teams cache in macOS
If Teams is still running, right-click the Teams icon in the dock, and then select Quit, or press Command (⌘)-Q.
In the Finder, open the /Applications/Utilities folder, and then double-click Terminal.
Enter the following command, and then press Return:
rm -r ~/Library/Application\ Support/Microsoft/Teams
Restart Teams.
This usually fixes these types of issues but if not, you'll have to make sure that the proper drivers for your Jabra 75 are installed in your PC. You may download it from here.
https://www.apac.jabra.com/supportpages/jabra-e...
69 additional answers
    2023-10-02T14:27:16+00:00
    Like everyone here I've been having this problem for a long time, and it is NOT fixed.
    I have Bose QuietComfort 35 II bluetooth headphones and after leaving a Teams call they stay in mono bi-directional mode.
    Turning my headphones OFF then ON again make them reconnect to the PC and that fixes the issue.
    2023-10-03T10:49:11+00:00
    Yep, same problem here.
    BTW: I removed the USB dongle and replaced it, in the case that restarting Teams didn't fix it, on my Jabra headset.
    Does look like the issue has persisted or reappeared.
    2023-10-11T05:27:53+00:00
    Has anyone opened a MS support case for this reoccurring issue and if yes, could post the case number?
    My supporter is currently saying, that no other Admin has reported this issue, which seems quite unbelievable.
    Holger
    2023-10-13T15:33:42+00:00
    Hello Holger.
    This is not true. And it is funny to hear that standpoint, I must admit.
    They should have a look at the tracking #2309211420002654
    A fix to adress the issue is scheduled for November
