Managing sound and video settings during Teams meetings and calls for optimal communication
This sound has been driving me absolutely nuts for weeks but think I have finally sorted it (for me anyway) and maybe you could try this also.......
- Right click the volume button in the start menu or far right on taskbar and select "Sounds"
- Click on the Recording tab, and select your Shokz/Aftershokz Headset. Click "Properties"
- Go to the "Levels" tab and you might see that your headset is muted by default for some reason. Unclick it and you should get a verbal notification that the mute is now off and the beep has gone!
