MS Teams Crashes when using a camera
2020-08-04T13:41:22+00:00
I am experiencing regular crashes of MS teams when i enable either the internal or an external camera.
The separate camera app works fine as does camera capabilities in other video apps such as zoom.
am running win 10
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
    2020-08-04T13:48:40+00:00
    Good day! I'm Raniel, an Independent Advisor and a Microsoft user like you.
    Kindly try to perform the steps on this article and see if it fixes the issue: https://windows101tricks.com/webcam-freezes-win...
    Have you also tried to login using MS Teams web app https://go.microsoft.com/fwlink/p/?LinkID=87302... to further isolate the issue?
    I also suggest to uninstall the desktop app via control panel, delete the files under %appdata%\Microsoft\teams\Cache and %appdata%\Microsoft\teams\Application Cache\Cache, perform a reboot and try to install the latest version via https://www.microsoft.com/en/microsoft-365/micr...
    You may also run the SFC and DISM command as well to repair system files
    1. On the search bar, type "command prompt" and select Run as administrator
    2. Type the following commands in order
    sfc /scannow then press Enter
    Dism.exe /online /cleanup-image /CheckHealth then press Enter
    Dism.exe /online /cleanup-image /ScanHealth then press Enter
    Dism.exe /online /cleanup-image /RestoreHealth then press Enter
    rundll32.exe pnpclean.dll,RunDLL_PnpClean /DRIVERS /MAXCLEAN then press Enter
    1. Perform a reboot once done and check again.
    I hope this helps.
    ________________________________________________________
    2020-08-04T18:51:19+00:00
    I have worked my way through most of your suggested fixes with no positive result.
    I am pretty sure the latest teams release version 1.3.00.1973 is the issue. Not only does the camera stop working the session does not 'release' the camera upon completion of the meeting.
    Seems like the only way to release the camera is to kill teams via the task manager.
    I think we need a new patch for teams
    2020-08-05T08:35:00+00:00
    Hi EugeneNOC,
    Apologies if the suggested methods didn't work. Have you also tried to temporarily disable your antivirus and check again? as well as ensure that you are running the latest version of Windows 10. I also suggest to perform a repair install of your Windows:
    https://www.tenforums.com/tutorials/16397-repai...
    https://www.yourwindowsguide.com/2016/06/how-to...
    2020-10-29T09:01:25+00:00
    I am having the exact same problem as EugeneNOC with the exception of this occurs with both Teams and Zoom. The issue started immediately after Teams released the update that allowed a second window during Teams meetings.
    2020-11-06T10:09:59+00:00
    How can you advise to disable antivirus?
    Teams is a monster in eating RAM and CPU when you use camera.
    MS just needs to fix this
