Audio output through bluetooth not working in teams app android
2021-06-25T11:45:36+00:00
I  am  using Teams  app  android  to  attend  my online classes  but I am facing issues  with bluetooth speaker. I wanted  to  use  Nest  mini  for  audio  output so  I   paired  to  it through bluetooth  on  my android device and  audio  output of  all  the  apps  work  except teams. This  issue  seems  to  be  only  on  android  app  because on  the  desktop app on  windows 10 the  same  speaker  works  absolutely fine. In  the  android app  when  I  try  to  switch  the  audio  output to  bluetooth, within  a  second it  switches  back  to  device  audio. I  tried on another android device as  well  but no luck. I  am  running the  latest  teams  version  (as  no  updates  available in  Play  store). Any  help  is  welcome.
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Audio and video
    2023-07-19T10:33:33+00:00
    Still experiencing this issue, seeing it's still ongoing after more than 2 years is hilarious. I managed to use my Sony Linkbuds for just one call with a random combination of uninstall/reinstall, deauthorize/authorize, pair/unpair etc., but I am not aware of and should not ever do any procedure other than connect/disconnect or switch off and on Bluetooth output. Headphones work with every other app and with the computer, so only problem here is that you need to fix this app.
    • Bluetooth output device is visible in call menu
    • If I enable it, it doesn't work
    • If I disconnect and reconnect headset, I hear few ms of audio and then goes back to phone speaker
    • there is no workaround among uninstall/reinstall, cache cleaning, unpairing and others mentioned here that works 10 times out of 10. Some of them never worked, some worked once or twice, completely randomly.
    2023-06-20T10:40:21+00:00
    Uninstall and install again the Teams App and problem solved!
    2023-05-25T17:19:28+00:00
    Teams doesn't work with Bluetooth audio on a Pixel 7, latest updates, with Pixel Buds earphones. If Microsoft can't get that pretty standard Android hardware working it's time to put in some more effort!
    2023-04-18T16:06:48+00:00
    Fun enough I have similar problem with my bose quietcomfort earbuds II, it used to work and now it doesn't.
    The really interesting part is that the mic from the Bluetooth works but I don't hear any sound whatsoever...
    When I use the speakers obviously the sound works again.
    I tried everything mentioned before, clear cache, reinstall, unpairing etc...
    100% a bug on MS Teams I think but any tips would be interesting
    2023-04-17T15:58:03+00:00
    I solved by allowing "nearby devices" in Setting - App - Teams in my Android smartphone but it worked only after unistalling and install back again the app
    Simone
