Several problems with hard drives, with CHKDSK and EFI partition
2022-04-15T17:53:59+00:00
My first problem is that i run powershell with admin rights and ran chkdsk f: /f /r . I thought it would restart pc after that but no, just started running chkdsk until now, so i could access the disk. Now, after about 3 hours total progress is 0%, but in phase 2, is this normal? should i wait? HD is not SSD and with 3.63TB capacity. I made chkdsk previously with CMD and didnt take so long, maybe is slower cause didnt boot windows?
Another problem is that the hard drive which made the windows boot was hit and cant be recovered. I had a SSD with the old windows partition, but dont know why needed this other hard drive to boot, i couldnt start Windows so i saw in the internet that could use bootrec /fixmbr, then bootrec /fixboot and then bootrec /rebuildcbd but that just made it worse. After making a clean install in other SSD i see the old windows partition in the other SSD shows my partition with all the data as EFI dont know why and cant access it, i tried to assign it a letter but gives me access denied
    2022-04-17T19:32:38+00:00
    I realized my windows is not updated, my version is version 1511 and the last version is 1809, i check for new updates but it doesnt update higher than 1511
  2. Igor Leyko 112.4K Reputation points Independent Advisor
    2022-04-17T18:54:37+00:00
    > Seems like hard drive goes back live and dead randomly
    Yes, this is possible.
    2022-04-17T18:44:59+00:00
    I see again the letter of the hard drive and hard drive apps are detecting it again like Easeus or Disk Drill, but not DMDE, i will see if they do something. Seems like hard drive goes back live and dead randomly
    2022-04-17T18:42:10+00:00
    You are an ****
  5. Igor Leyko 112.4K Reputation points Independent Advisor
    2022-04-17T16:24:31+00:00
    > DMDE doesnt recognice my hard drive, neither the BIOS
    This means hardware problems with this drive. In your Easeus link this is described as "Your drive is dead". Sorry for bad news.
