I realized my graphic card is not detected also, it worked fine before the clean installation, and i see it has power
Several problems with hard drives, with CHKDSK and EFI partition
My first problem is that i run powershell with admin rights and ran chkdsk f: /f /r . I thought it would restart pc after that but no, just started running chkdsk until now, so i could access the disk. Now, after about 3 hours total progress is 0%, but in phase 2, is this normal? should i wait? HD is not SSD and with 3.63TB capacity. I made chkdsk previously with CMD and didnt take so long, maybe is slower cause didnt boot windows?
Another problem is that the hard drive which made the windows boot was hit and cant be recovered. I had a SSD with the old windows partition, but dont know why needed this other hard drive to boot, i couldnt start Windows so i saw in the internet that could use bootrec /fixmbr, then bootrec /fixboot and then bootrec /rebuildcbd but that just made it worse. After making a clean install in other SSD i see the old windows partition in the other SSD shows my partition with all the data as EFI dont know why and cant access it, i tried to assign it a letter but gives me access denied
2022-04-15T23:16:21+00:00 -
2022-04-15T23:15:47+00:00 I just found this web https://pcpartpicker.com/products/motherboard/?compatible_with=WGZ2FT says it is compatible
2022-04-15T23:12:47+00:00 i use Kingston SSDNow A400 240GB 2.5 SATA3 and gigabyte B450 as motherboard Gigabyte B450 AORUS Pro Socket AM4. How can i check if it is compatible?
Igor Leyko 112.4K Reputation points Independent Advisor
2022-04-15T22:50:14+00:00 Please check if you SSD is in motherboard's compatibility list. May be it is needed to update SSD firmware or computer's BIOS.
2022-04-15T22:29:15+00:00 I am starting to think this is not related to my hard drive, my new SSD is taking minutes to just delete one file, something is going on here dont know what
