I'm talking about your hard drive. And its unstable operation may cause problems with Windows booting.
Several problems with hard drives, with CHKDSK and EFI partition
My first problem is that i run powershell with admin rights and ran chkdsk f: /f /r . I thought it would restart pc after that but no, just started running chkdsk until now, so i could access the disk. Now, after about 3 hours total progress is 0%, but in phase 2, is this normal? should i wait? HD is not SSD and with 3.63TB capacity. I made chkdsk previously with CMD and didnt take so long, maybe is slower cause didnt boot windows?
Another problem is that the hard drive which made the windows boot was hit and cant be recovered. I had a SSD with the old windows partition, but dont know why needed this other hard drive to boot, i couldnt start Windows so i saw in the internet that could use bootrec /fixmbr, then bootrec /fixboot and then bootrec /rebuildcbd but that just made it worse. After making a clean install in other SSD i see the old windows partition in the other SSD shows my partition with all the data as EFI dont know why and cant access it, i tried to assign it a letter but gives me access denied
2022-04-15T20:55:37+00:00 Also is strange that windows update just updated a few packages, normally needs updating a lot of packages in a clean install
2022-04-15T20:54:52+00:00 But the drive where i installed windows is new SSD and also all nvidia drivers tell me they dont support my windows version, but i download 64 bit windows 10 as Windows tells me i am using 64 bit, i tried to run a not demanding game and my CPU was being used 90% for no reason, even though i had the AMD drivers installed
Igor Leyko 112.4K Reputation points Independent Advisor
2022-04-15T20:51:12+00:00 Unfortunately this may mean your drive is on the way to death. Please make a backup of all your data ASAP.
2022-04-15T20:28:44+00:00 Also everything go sluggish and it is a clean install, what hel hell is going on in my pc
