USB power setting is missing from the Power Options (running Windows 11)
2022-04-03T16:35:44+00:00
I am trying to manage my USB power plan settings but the USB option is missing from the Advanced Power Settings option.
Control Panel/System and Security/Power Options/Edit Plan Settings/Change Advanced Power Settings
FYI:
I am running Windows 11 Home Version 21H2 on an HP Spectre laptop.
I tried some fixes posted for Windows 10, but they did not work.
NOTE: I am trying to change the USB power options to see if this will stop the flickering in my Logi HD 1080p Webcam.
    2024-05-22T20:33:39+00:00
    my USB works very well I don't know what is your complaint ....?
  2. Deleted
    2024-05-22T20:23:55+00:00
    Hi Microsoft Team,
    I have two issues right now are listed below.
    1.USB Power Setting is missing from power options.
    Even I have followed the instructions. However, problem still the same.
    2.In Device Manager in Ports (COM & LPT) one unknown device error I have.
    Reply
    USB\VID_15A2&PID_005A&USB2SER (error)
    2024-03-13T15:47:01+00:00
    why it is so hard to find my android watch installing in usb
    2024-02-22T20:07:18+00:00
    Hello there.
    All three my USB ports are disabled.
    all updated newly.
