How to disable noise suppression when an application is using the microphone.
2022-09-16T20:18:02+00:00
Whenever an application is using my microphone, all the audio that plays gets suppressed and muffled and nearly quiet, there was an option to disable this before, but I just don't know how to disable it.
Disabling the options such as Audio Enhancements will make it normal for around 2 seconds before it becomes muffled again.
    2024-09-01T19:13:09+00:00
    Thanks, I'll try their help desk
    2024-09-21T18:41:49+00:00
    PLEASE READ, FOR ANYONE THAT NEEDS HELP WITH THIS....
    SEARCH "REALTEK AUDIO CONSOLE" IN YOUR WINDOWS SEARCH BAR.
    OPEN APPLICATION
    DISABLE "SPEAKER NOISE CANCELLATION"
    IT WORKS!
    I HAVE BEEN DEALING WITH THIS FOR MONTHS AND FINALLY FIGURED IT OUT! HALLELUJAH!
