Drive appears when in system properties
2022-12-24T13:28:12+00:00
This drive appeared from nowhere when I was checking for restore points. I only have one user and this drive (\?\Volume{a6810e9c-7196-4ad5...) does not appear anywhere else. I haven't been able to remove it, not because it's causing performance issues or anything, but simply because it bugs me. Any idea what that is and how to remove it?
I've tried resetting my laptop several times but all in vain. Is there any solution for this?
2022-12-31T15:41:51+00:00
The log says winre.wim can't be found even though the file is present there.
Pls try:
  • attrib -s -h -r c:\windows\system32\recovery\reagent.xml
  • del c:\windows\system32\recovery\reagent.xml /a
  • REAGENTC /disable
  • copy c:\winre.wim T:\Recovery\WindowsRE /y
  • REAGENTC /setreimage /path T:\Recovery\WindowsRE /target C:\Windows
  • REAGENTC /enable
114 additional answers
    2022-12-27T03:23:06+00:00
    Recreating the partition is recommended.
    Let's create the partition using DiskPart.
    • DiskPart
    • sel disk 0
    • create partition primary size=1130
    • format fs=NTFS quick label=WinRE
    • set id=de94bba4-06d1-4d40-a16a-bfd50179d6ac
    • lis par
    • lis vol
    Pls post a screenshot.
  2. Deleted
    2022-12-27T11:44:57+00:00
    I understand. Here's the result!
    2022-12-27T11:46:18+00:00
    Now WinRe is listed instead.
