Drive appears when in system properties
2022-12-24T13:28:12+00:00
This drive appeared from nowhere when I was checking for restore points. I only have one user and this drive (\?\Volume{a6810e9c-7196-4ad5...) does not appear anywhere else. I haven't been able to remove it, not because it's causing performance issues or anything, but simply because it bugs me. Any idea what that is and how to remove it?
I've tried resetting my laptop several times but all in vain. Is there any solution for this?
2022-12-31T15:41:51+00:00
The log says winre.wim can't be found even though the file is present there.
Pls try:
  • attrib -s -h -r c:\windows\system32\recovery\reagent.xml
  • del c:\windows\system32\recovery\reagent.xml /a
  • REAGENTC /disable
  • copy c:\winre.wim T:\Recovery\WindowsRE /y
  • REAGENTC /setreimage /path T:\Recovery\WindowsRE /target C:\Windows
  • REAGENTC /enable
114 additional answers
    2022-12-26T13:10:52+00:00
    Type;
    • sel par 4
    • del par override
    • exit
    • exit
    Restart Windows and see if the entry is removed in the System Restore dialog.
    After restarting, we need to recreate the partition.
    2022-12-26T13:21:18+00:00
    Do you think reinstalling windows via disk image (iso) would resolve the issue and other issues potentially?
    2022-12-26T13:29:27+00:00
    Reinstallation may not be needed for this issue, I think (especially as you reset the PC earlier). I'll take a look at the Memory Integrity problem you posted on another thread.
    2022-12-26T22:05:31+00:00
    The drive is no longer listed after deleting the partition! I am really grateful for your help. Do we really need to recreate the partition?
    The memory intergrity issue hasn't been resolved, I'll link the thread below if feel you like you can help with that!
    https://answers.microsoft.com/en-us/windows/forum/all/memory-intergrity-wont-turn-on/073e9dab-5036-4827-995b-d97ee2deaeae
