Drive appears when in system properties
2022-12-24T13:28:12+00:00
This drive appeared from nowhere when I was checking for restore points. I only have one user and this drive (\?\Volume{a6810e9c-7196-4ad5...) does not appear anywhere else. I haven't been able to remove it, not because it's causing performance issues or anything, but simply because it bugs me. Any idea what that is and how to remove it?
I've tried resetting my laptop several times but all in vain. Is there any solution for this?
2022-12-31T15:41:51+00:00
The log says winre.wim can't be found even though the file is present there.
Pls try:
  • attrib -s -h -r c:\windows\system32\recovery\reagent.xml
  • del c:\windows\system32\recovery\reagent.xml /a
  • REAGENTC /disable
  • copy c:\winre.wim T:\Recovery\WindowsRE /y
  • REAGENTC /setreimage /path T:\Recovery\WindowsRE /target C:\Windows
  • REAGENTC /enable
114 additional answers
    2022-12-30T18:40:37+00:00
    Winre.wim size from my Windows 11 22H2 ISO. The file's date is the same, but the size is different.
    Think your WIM might be corrupted and failed the hash validation check by Reagentc?!
  2. Deleted
    2022-12-30T23:09:28+00:00
    I've tried different methods now and extracted the Winre.wim instead of cutting and pasting several times. This is the file size now.
    Everything is happening successfully in the command prompt however it still shows "Windows RE status: disabled". Winre.wim file is now available in both C: and T: drives.
    2022-12-31T03:03:36+00:00
    Interesting. I see a different file size here.
    Try:
    Extract a new copy of winre.wim from ISO and place it in c:\winre.wim.
    Then run:
    md c:\recovery\windowsre
    copy "c:\winre.wim" "c:\recovery\windowsre"
    reagentc /setreimage /path c:\recovery\windowsre /target c:\windows
    reagentc /enable
    reagentc /info
