Drive appears when in system properties
2022-12-24T13:28:12+00:00
This drive appeared from nowhere when I was checking for restore points. I only have one user and this drive (\?\Volume{a6810e9c-7196-4ad5...) does not appear anywhere else. I haven't been able to remove it, not because it's causing performance issues or anything, but simply because it bugs me. Any idea what that is and how to remove it?
I've tried resetting my laptop several times but all in vain. Is there any solution for this?
2022-12-31T15:41:51+00:00
The log says winre.wim can't be found even though the file is present there.
Pls try:
  • attrib -s -h -r c:\windows\system32\recovery\reagent.xml
  • del c:\windows\system32\recovery\reagent.xml /a
  • REAGENTC /disable
  • copy c:\winre.wim T:\Recovery\WindowsRE /y
  • REAGENTC /setreimage /path T:\Recovery\WindowsRE /target C:\Windows
  • REAGENTC /enable
114 additional answers
    2022-12-29T02:04:33+00:00
    Great, thanks. Run "reagentc /info" to confirm.
    2022-12-29T05:30:55+00:00
    This error occurs when I run "reagentc /info".
    2022-12-29T05:42:07+00:00
    Try:
    • reagentc /disable
    • reagentc /setreimage /path \?\globalroot\device\harddisk0\partition4\recovery\windowsre /target c:\windows
    Pls upload "C:\Windows\Logs\ReAgent\ReAgent.log"
    2022-12-29T13:19:16+00:00
