Drive appears when in system properties
2022-12-24T13:28:12+00:00
This drive appeared from nowhere when I was checking for restore points. I only have one user and this drive (\?\Volume{a6810e9c-7196-4ad5...) does not appear anywhere else. I haven't been able to remove it, not because it's causing performance issues or anything, but simply because it bugs me. Any idea what that is and how to remove it?
I've tried resetting my laptop several times but all in vain. Is there any solution for this?
2022-12-31T15:41:51+00:00
The log says winre.wim can't be found even though the file is present there.
Pls try:
  • attrib -s -h -r c:\windows\system32\recovery\reagent.xml
  • del c:\windows\system32\recovery\reagent.xml /a
  • REAGENTC /disable
  • copy c:\winre.wim T:\Recovery\WindowsRE /y
  • REAGENTC /setreimage /path T:\Recovery\WindowsRE /target C:\Windows
  • REAGENTC /enable
114 additional answers
    2022-12-24T14:09:43+00:00
    Thanks for the response. This is how far I've come. I could not run "Get-WMIObject win32_volume | Format-List -property Label, DriveLetter, DeviceID, SystemVolume, Capacity" for some reason. What I did is copy and paste the command above, open run WIN+R and paste, the last screenshot shows the error message.
    2022-12-24T13:41:48+00:00
    In the System Restore dialog, select that unknown drive and click Configure.
    Select the slider to Max.
    Note down the disk size reported.
    Click Cancel to close the dialog.
    From Admin PowerShell, run:
    • diskpart
    And then run:
    • list volume
    (Take a screenshot of the output window.)
    • exit
    Run:
    • Get-WMIObject win32_volume | Format-List -property Label, DriveLetter, DeviceID, SystemVolume, Capacity
    • Mountvol
    Please upload the screenshots here.
