HI PCR .. in reading through your last response, there is much to digest there. I decided to tackle each item, one by one starting with (1) question in green below, and post the results from there before continuing on to part 2 whuch I =need ed to reread several times. I am hoping that this first question being answered will be able to determine what if anything needs to be done next. I have included screen shots of disk management as well as diskpart info as requested. lets see where we are at now.
(1) Can you do those BCDEdit commands while booted to Windows? YES I can How about at the internal recovery environment (Shift+Restart)? Did Not TRy since was able to do it in windows directly Then let me see a "BCDEdit /Enum All".
yes... I managed to do several BCDEdit commands and have them work while booted to windows. included creating the backup of the BCD and the BCDEdit /Enum all. See the bolded text below
2021-10-27 11:12 AM
Microsoft Windows [Version 10.0.19042.1288]
(c) Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>cd \
C:>dir
Volume in drive C is Local Disk
Volume Serial Number is 3FA8-6782
Directory of C:\
09/13/2021 02:14 PM <DIR> $WINDOWS.~BT
09/12/2019 05:33 PM 0 a.txt
10/14/2014 09:06 PM 72 Autoconfig.ini
10/12/2021 06:18 PM 31,834 b$ cclear-ON1 and others 2021-10-12.reg
10/25/2021 01:16 PM <DIR> BU
04/08/2014 07:34 PM 262,144 BzEngineTempFile16217.dk
03/22/2016 05:23 PM 9,835 config.xml
09/26/2019 08:56 AM <DIR> easeus_tb_cloud
09/13/2021 05:03 PM <DIR> ESD
04/29/2020 06:40 PM <DIR> HP Universal Print Driver
03/11/2016 06:13 PM <DIR> HP_LaserJet_Pro_MFP_M127-M128
08/11/2021 12:57 PM <DIR> HP_LaserJet_Pro_MFP_M225-M226
03/11/2016 07:18 PM <DIR> HP_M127_128_FW_Update
12/05/2020 02:38 PM <DIR> inetpub
11/08/2016 09:38 AM 68,400 INFO.2
01/03/2014 03:32 PM <DIR> Intel
04/26/2016 11:35 PM <DIR> Logs
09/04/2019 06:21 PM 562 most recent - map network drive to Igiveup.reg
10/21/2016 08:36 AM <DIR> NPE
12/07/2019 02:14 AM <DIR> PerfLogs
10/23/2021 05:10 PM <DIR> Program Files
10/12/2021 04:56 PM <DIR> Program Files (x86)
12/02/2014 09:40 PM <DIR> reduced size
12/07/2019 12:49 PM <DIR> Reg backup
10/21/2016 08:28 AM 248 rescue.info
08/17/2015 05:46 PM <DIR> System.sav
09/09/2021 02:00 PM <DIR> temp
07/09/2021 04:46 PM <DIR> Users
10/26/2021 05:10 PM <DIR> Windows
12/23/2017 08:14 PM <DIR> Windows10Upgrade
8 File(s) 373,095 bytes
22 Dir(s) 709,660,008,448 bytes free
C:>cd windows
C:\Windows>cd system32
<<<<<<<<<------- entered dir command here and listed a ton of directories that I deleted as irrelevent here------------>
5068 File(s) 2,770,439,279 bytes
211 Dir(s) 709,659,840,512 bytes free
C:\Windows\System32>cd bu
The system cannot find the path specified.
C:\Windows\System32>cd \bu
C:\BU>dir
Directory of C:\BU
10/25/2021 01:16 PM <DIR> .
10/25/2021 01:16 PM <DIR> ..
**0 File(s) 0 bytes**
**2 Dir(s) 709,659,119,616 bytes free**
C:\BU>bcdedit /Export C:\bu\BCD_Backup
The operation completed successfully.
C:\BU>dir
Directory of C:\BU
10/27/2021 11:11 AM <DIR> .
10/27/2021 11:11 AM <DIR> ..
10/27/2021 11:11 AM 32,768 BCD_Backup
**1 File(s) 32,768 bytes**
**2 Dir(s) 709,658,501,120 bytes free**
C:\BU>
exited from cmd at this point
came back into Cmd here and tried the BCDEit /Enum all...
C:\WINDOWS\system32>bcdedit /enum All
Firmware Boot Manager
identifier {fwbootmgr}
displayorder {c4337ee8-11b0-11ec-ab4f-806e6f6e6963}
{c4337ee7-11b0-11ec-ab4f-806e6f6e6963}
{c4337ee3-11b0-11ec-ab4f-806e6f6e6963}
{c4337ee6-11b0-11ec-ab4f-806e6f6e6963}
timeout 0
Windows Boot Manager
identifier {bootmgr}
device unknown
description Windows Boot Manager
locale en-US
inherit {globalsettings}
default {current}
resumeobject {00699258-3744-11eb-956e-efd836ee9db2}
displayorder {current}
toolsdisplayorder {memdiag}
timeout 30
Firmware Application (101fffff)
identifier {c4337ee3-11b0-11ec-ab4f-806e6f6e6963}
description CD/DVD Drive
identifier {c4337ee6-11b0-11ec-ab4f-806e6f6e6963}
device partition=\Device\HarddiskVolume2
path \EFI\MICROSOFT\BOOT\BOOTMGFW.EFI
identifier {c4337ee7-11b0-11ec-ab4f-806e6f6e6963}
description Hard Drive
identifier {c4337ee8-11b0-11ec-ab4f-806e6f6e6963}
path \EFI\Microsoft\Boot\bootmgfw.efi
Windows Boot Loader
identifier {current}
device partition=C:
path \WINDOWS\system32\winload.efi
description Windows 10
locale en-US
inherit {bootloadersettings}
recoverysequence {201ca33c-3744-11eb-ab08-a9da93046d68}
displaymessageoverride Recovery
recoveryenabled Yes
allowedinmemorysettings 0x15000075
osdevice partition=C:
systemroot \WINDOWS
nx OptIn
bootmenupolicy Standard
Windows Boot Loader
identifier {201ca33c-3744-11eb-ab08-a9da93046d68}
device partition=H:
path \windows\system32\winload.efi
description Windows Recovery Environment
locale en-US
displaymessage Recovery
osdevice partition=H:
systemroot \windows
nx OptIn
winpe Yes
Windows Boot Loader
identifier {becbfbbb-74c1-11e3-a193-d3e592cc6be4}
device partition=C:
systemroot \windows
nx OptIn
winpe Yes
Resume from Hibernate
identifier {00699258-3744-11eb-956e-efd836ee9db2}
device partition=C:
path \WINDOWS\system32\winresume.efi
description Windows Resume Application
locale en-US
inherit {resumeloadersettings}
recoveryenabled Yes
filedevice partition=C:
filepath \hiberfil.sys
debugoptionenabled No
Windows Memory Tester
identifier {memdiag}
device unknown
path \boot\memtest.exe
description Windows Memory Diagnostic
locale en-US
badmemoryaccess Yes
EMS Settings
identifier {emssettings}
bootems No
Debugger Settings
identifier {dbgsettings}
debugtype Serial
debugport 1
baudrate 115200
RAM Defects
identifier {badmemory}
Global Settings
identifier {globalsettings}
inherit {dbgsettings}
{emssettings}
{badmemory}
Boot Loader Settings
identifier {bootloadersettings}
{hypervisorsettings}
Hypervisor Settings
identifier {hypervisorsettings}
hypervisordebugtype Serial
hypervisordebugport 1
hypervisorbaudrate 115200
Resume Loader Settings
identifier {resumeloadersettings}
Device options
identifier {201ca33d-3744-11eb-ab08-a9da93046d68}
ramdisksdidevice partition=H:
ramdisksdipath \Recovery\WindowsRE\boot.sdi
Device options
identifier {becbfbbc-74c1-11e3-a193-d3e592cc6be4}
description Ramdisk Options
ramdisksdidevice partition=C:
ramdisksdipath \Recovery\becbfbbb-74c1-11e3-a193-d3e592cc6be4\boot.sdi
then exited.
disk management screen shot...follows
C:\WINDOWS\system32>diskpart
Microsoft DiskPart version 10.0.19041.964
Copyright (C) Microsoft Corporation.
On computer: GARRY-INTEL1
DISKPART> list vol
Volume ### Ltr Label Fs Type Size Status Info
Volume 0 Y DVD-ROM 0 B No Media
Volume 1 Z DVD-ROM 0 B No Media
Volume 2 C Local Disk NTFS Partition 930 GB Healthy Boot
Volume 3 FAT32 Partition 100 MB Healthy System
Volume 4 H NTFS Partition 627 MB Healthy Hidden
Volume 5 D Application NTFS Partition 58 GB Healthy
Volume 6 E Data1 NTFS Partition 429 GB Healthy
Volume 7 F Data2 NTFS Partition 488 GB Healthy
Volume 8 G WorkArea1 NTFS Partition 886 GB Healthy
Volume 9 I Removable 0 B No Media
Volume 10 J Removable 0 B No Media
Volume 11 K Removable 0 B No Media
Volume 12 M Removable 0 B No Media
DISKPART> select vol 3
Volume 3 is the selected volume.
DISKPART> detail part
Partition 2
Type : c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Hidden : Yes
Required: No
Attrib : 0X8000000000000000
Offset in Bytes: 135266304
* Volume 3 FAT32 Partition 100 MB Healthy System
DISKPART> exit
Leaving DiskPart...
DISKPART> select disk 0
Disk 0 is now the selected disk.
DISKPART> list part
Partition ### Type Size Offset
Partition 1 Reserved 128 MB 17 KB
Partition 2 System 100 MB 129 MB
Partition 3 Primary 930 GB 229 MB
Partition 4 Recovery 627 MB 930 GB
DISKPART> exit
Leaving DiskPart...
DISKPART> select vol 2
Volume 2 is the selected volume.
Partition 3
Type : ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
Hidden : No
Required: No
Attrib : 0000000000000000
Offset in Bytes: 240123904
* Volume 2 C Local Disk NTFS Partition 930 GB Healthy Boot
DISKPART> exit
Leaving DiskPart...
I did try to deal with item (2) of yours but I may not have booted correctly into the bios as I just did the normal delete key press while booting. The link you provided says different key required to get to the bootmgr options. Doing it the way I did, produced the same failed results as before with the BCDEdit commands.
If you want me to go ahead and follow the steps in item 2 more carefully this time I will if you think it is necessary.
Thanks again for all your help.
Cheers!
Garry
