Onedrive seems to have created its own drive G partition and moved my previous drive G partition to drive L
2021-10-01T22:00:28+00:00
One drive has messed up my partitions in that I had a drive G called WorkArea (G) that has the one drive folders to sync on it, along with all other files and folders on it. Somehow my G drive WorkArea (G) (partition) was reallocated to drive L WorkArea (L), and a separate partition G now called Local Disk (G). has appeared in the original drive G's place. (not talking about drive Mapping here).
In windows explorer I see the following screen shot
whereas in disk management, G does NOT show up at all and I cannot change WorkArea (L) back to G.
Drive L does show up in windows explorer, but is not in the screen shot. .
and trying to re-assign WorkArea to G I cannot, as it is unavailable.
how do I fix this?
I tried to uninstall OneDrive, and reboot but nothing changed.
Can someone please help me fix this as my backup plans are set for G as what is in WorkArea L and now backup of G only shows OneDrive files, that were not part of the backup plan to begin with.
Thanks for any help you can offer. Much appreciated.
Garry G
    2021-10-20T01:02:51+00:00
    Deleted & reposted as I recalled Bootrec exists only in the recovery environment.
    You are welcome. Bootrec only exists in the recovery environment. It's really best to have a Recovery drive or Installation media to get there in this circumstance. Do you have one? Those have an external recovery environment onboard. Otherwise...
    (a) Hold Shift as you click Restart to get to the internal recovery environment.
    (b) Click "Troubleshoot > Advanced Options > Command Prompt".
    (c) Enter the following commands...
    DiskPart <<<Enter DiskPart
    List Vol <<<List the volumes & their letters
    Exit <<<Exit DiskPart
    === You should recognize the Windows volume by its label or size ===
    === Note its letter which may not be C: in this environment ===
    === Use that letter instead of X: in the following commands ===
    MD X:\BU <<<Make a folder on "C:" named BU
    BCDEdit /Export X:\BU\BCD_Backup <<<Backup the BCD into it
    Select Disk 0 <<<Focus on disk 0
    List Part <<<List the partitions
    Select Part 2 <<<Focus on partition 2 (EFI System)
    Assign Letter=S <<<Give it letter S:
    REN S:\efi\microsoft\boot\bcd bcd_old <<<Rename current BCD
    Bootrec /RebuildBCD <<<Create fresh BCD
    Select Vol=S <<<Focus on EFI
    Remove Letter=S <<<Remove the letter
    That should do it. Close the Command Prompt, & click "Continue" to return to Windows. At an Admin Command Prompt, enter...
    BCDEdit /Enum All <<<Show the new BCD
    Use Ctrl-A & Ctrl-C to copy, then post it here. I'm unsure the Recovery partition will have activated so that Shift+Restart will continue to work. If not, we can then activate it manually.
    If it won't reboot, get into the recovery environment...
    (a) An error message may have an "Advanced Options" button that gets there.
    (b) Shut the computer 2 times as it tries to boot. On the 3rd attempt to boot it should go there.
    (c) Use a Recovery drive or Installation media to get there. Need instructions?
    Then, at the "Choose an Option" screen...
    (a) Click "Troubleshoot > Advanced Options > Command Prompt".
    (b) Enter the following commands...
    === Use that letter instead of X: in the following command ===
    BCDEdit /Import X:\BU\BCD_Backup /Clean <<<Restore the backup BCD
  2. Deleted
    2021-10-19T22:44:13+00:00
    Hi PCR....
    Am trying to follow what your are saying about the BCD?
    "I don't know, maybe we should let it be, but I'm inclined to want to regenerate your BCD. Here is what mine looks like...
    (a) {bootmgr} is on top in the Firmware Boot Manager.
    (b) There are no duplicate, malformed or unused sections.
    Microsoft Windows [Version 10.0.19043.1288]
    (c) Microsoft Corporation. All rights reserved.
    *C:\Windows\system32>*bcdedit /enum all
    Firmware Boot Manager "
    there is a lot of information after this that I have no idea what it is all about or where or how it is produced.
    If I am to create a new BCD can you walk me through the steps please, as you did withthe previous part. Where to start and what to do.
    thansk again.
    Garry
    2021-10-18T00:17:24+00:00
    You are welcome. That looks like a big success so far. Disk Management is showing the Recovery partitions appropriately in both its upper (disk 0 partition 4) & lower pane. DiskPart shows the letter is gone. You are free to use G: elsewhere. Hopefully, the mishap will not recur. I'm unsure what caused it in the first place. I do know, in these later versions of Windows, a letter gets automatically put onto the Recovery partition when you boot into the recovery environment. Also, the letters may scramble & be different there. But it all should be back to normal when rebooted back to Windows. Matbe it was that Attrib value at fault. It wanted Windows to keep the letter on Recovery.
    I think your BCD needs a lot of work. I'm inclined to suggest we generate a new one altogether. You've got a {bootmgr} section in there, but it is malformed & unused. There are other unused sections. Instead, from fiirmware (fwbootmgr), there is a jump to this thing...
    Firmware Application (101fffff)
    identifier {c4337ee6-11b0-11ec-ab4f-806e6f6e6963}
    device partition=\Device\HarddiskVolume2
    path \EFI\MICROSOFT\BOOT\BOOTMGFW.EFI
    description Windows Boot Manager
    That Device & Path belong in your {bootmgr}, & the firmware should be going there. But yours does appear to get the job done. If you hold Shift & click "Restart", does Windows reboot to the recovery environment at the "Choose an Option" screen? And does it have the full panoply of options, including Troubleshoot & Advanced Options buttons? I don't know, maybe we should let it be, but I'm inclined to want to regenerate your BCD. Here is what mine looks like...
    C:\Windows\system32>bcdedit /enum all
    identifier {fwbootmgr}
    displayorder {bootmgr}
                        {140ab3f9-3491-11e7-a4a0-952787f57a8e}
                        {140ab3fa-3491-11e7-a4a0-952787f57a8e}
    timeout 1
    identifier {bootmgr}
    device partition=\Device\HarddiskVolume1
    path \EFI\Microsoft\Boot\bootmgfw.efi
    locale en-US
    inherit {globalsettings}
    default {current}
    resumeobject {140ab3fc-3491-11e7-a4a0-952787f57a8e}
    displayorder {current}
    toolsdisplayorder {memdiag}
    timeout 30
    identifier {140ab3f9-3491-11e7-a4a0-952787f57a8e}
    description Onboard NIC(IPV4)
    identifier {140ab3fa-3491-11e7-a4a0-952787f57a8e}
    description Onboard NIC(IPV6)
    Windows Boot Loader
    identifier {current}
    device partition=C:
    path \Windows\system32\winload.efi
    description Windows 10
    locale en-US
    inherit {bootloadersettings}
    recoverysequence {140ab3fe-3491-11e7-a4a0-952787f57a8e}
    displaymessageoverride CommandPrompt
    recoveryenabled Yes
    isolatedcontext Yes
    allowedinmemorysettings 0x15000075
    osdevice partition=C:
    systemroot \Windows
    nx OptIn
    bootmenupolicy Standard
    Windows Boot Loader
    identifier {140ab3fe-3491-11e7-a4a0-952787f57a8e}
    device ramdisk=[\Device\HarddiskVolume4]\Recovery\WindowsRE\Winre.wim,{140ab3ff-3491-11e7-a4a0-952787f57a8e}
    path \windows\system32\winload.efi
    description Windows Recovery Environment
    locale en-us
    displaymessage Recovery
    osdevice ramdisk=[\Device\HarddiskVolume4]\Recovery\WindowsRE\Winre.wim,{140ab3ff-3491-11e7-a4a0-952787f57a8e}
    systemroot \windows
    nx OptIn
    winpe Yes
    Resume from Hibernate
    identifier {140ab3fc-3491-11e7-a4a0-952787f57a8e}
    device partition=C:
    path \Windows\system32\winresume.efi
    description Windows Resume Application
    locale en-US
    inherit {resumeloadersettings}
    recoveryenabled Yes
    isolatedcontext Yes
    filedevice partition=C:
    filepath \hiberfil.sys
    debugoptionenabled No
    Windows Memory Tester
    identifier {memdiag}
    path \EFI\Microsoft\Boot\memtest.efi
    description Windows Memory Diagnostic
    locale en-US
    badmemoryaccess Yes
    EMS Settings
    identifier {emssettings}
    bootems No
    Debugger Settings
    identifier {dbgsettings}
    debugtype Local
    RAM Defects
    identifier {badmemory}
    Global Settings
    identifier {globalsettings}
    inherit {dbgsettings}
                        {emssettings}
                        {badmemory}
    Boot Loader Settings
    identifier {bootloadersettings}
                        {hypervisorsettings}
    Hypervisor Settings
    identifier {hypervisorsettings}
    hypervisordebugtype Serial
    hypervisordebugport 1
    hypervisorbaudrate 115200
    Resume Loader Settings
    identifier {resumeloadersettings}
    Device options
    identifier {140ab3ff-3491-11e7-a4a0-952787f57a8e}
    ramdisksdidevice partition=\Device\HarddiskVolume4
    ramdisksdipath \Recovery\WindowsRE\boot.sdi
    2021-10-17T21:46:48+00:00
    Hi PCR ....
    Here is the latest as per your instructions. Thank you for your reply once again. Most appreciated.
    The disk management screen shot is at the end of the cmd information.
    In your last reply after the instructions, you said: the following, but I do not know what this means or what needs to be done next if anything. Can you please explain / clarify further ?
    "(2) The Firmware Boot Manager in the BCD is a window to the BIOS Boot menu screen. Yours isn't set normally for a UEFI installation.,,
    displayorder
    {c4337ee6-11b0-11ec-ab4f-806e6f6e6963} <<<Direct boot to EFI
    {c4337ee7-11b0-11ec-ab4f-806e6f6e6963} <<<Direct to a hard drive
    {c4337ee8-11b0-11ec-ab4f-806e6f6e6963} <<<Also direct boot to EFI
    {c4337ee3-11b0-11ec-ab4f-806e6f6e6963} <<<Boot to CD/DVD drive
    timeout 0
    It should instead boot to the Windows Boot Manager ({bootmgr}). You do have one in the BCD, but it is missing its device & path values. There is a lot amiss in your BCD. I'm thinking we should generate a new one altogether instead of tinkering with this one.
    cmd details follow here:
    Microsoft Windows [Version 10.0.19042.1237]
    C:\WINDOWS\system32>diskpart
    Microsoft DiskPart version 10.0.19041.964
    Copyright (C) Microsoft Corporation.
    On computer: GARRY-INTEL1
    DISKPART> select disk 0
    Disk 0 is now the selected disk.
    DISKPART> select part 4
    Partition 4 is now the selected partition.
    DISKPART> detail part
    Partition 4
    Type : de94bba4-06d1-4d40-a16a-bfd50179d6ac
    Hidden : Yes
    Required: No
    Attrib : 0000000000000000
    Offset in Bytes: 999546683392
    Volume ### Ltr Label Fs Type Size Status Info
    * Volume 4 G NTFS Partition 627 MB Healthy Hidden
    DISKPART> remove Letter=G
    DiskPart successfully removed the drive letter or mount point.
    DISKPART> GPT ATTRIBUTES=0x8000000000000001
    DiskPart successfully assigned the attributes to the selected GPT partition.
    Partition 4
    Hidden : Yes
    Required: Yes
    Attrib : 0X8000000000000001
    * Volume 4 NTFS Partition 627 MB Healthy Hidden
    DISKPART> exit
    and the view in file explorer now looks like this and note that there is no longer a drive G showing. I will now rename L: to G: so that my backups work again.
    Once again, thank you very much for your help so far. Nice to know that there is knowledgeable community help available, and that there are those like yourself willing to help. so grateful.
    Cheers!
    Garry
