Hi ThornySeeker6 -
Thank you for the detailed response and I apologize that the given methods did not work. If that's the case, please try to perform the other methods below.
Method 1: Perform SFC Scan and Repair Windows Image
-This process will perform scan for any corrupted system files or integrity violation and will attempt to repair it along with the Windows Image.
- Open command prompt with administrator access
- Type each command below and wait until scan is completed.
sfc /scannow
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
Quick note: While the command is running, it's expected to see the process stuck at 20 or 40 percent. After a few minutes, the process will complete successfully.
Once you complete the steps, the Deployment Image Servicing and Management tool will connect to the Windows Update servers to download and replace any damaged files in the local image for Windows 10 as necessary.
- Close the command prompt.
Method 2: In-Place Repair
- In-place repair/upgrade or repair reinstall is a process of re-installing Windows without touching any of your applications or personal files. In this way if there's any data corruption, damaged system files or missing system files on your computer, this repair will fix or repair them.
To start we need to download an ISO file of Windows 10 and save it to your computer. Please follow the instruction on the link below to create an ISO file
https://support.microsoft.com/en-us/help/402819...
After the ISO is created, follow the instructions on the link below created by PaulSey, Microsoft Agent, on how to perform repair install on your computer.
https://answers.microsoft.com/en-us/windows/for...
This process will take some time to complete so you need to be very patient in waiting until the process completes. Once done , restart your computer and check if the issue is resolved.
Please keep me posted for the result.
Regards,
Jerico T.
