advanced power options and csenabled
2020-11-03T11:21:15+00:00
Hi
Advanced power options went missing after the last update. No processor options, usb, gpu power, etc. The usual fix of CSEnabled in regedit is no longer there. The fan speed is out of control even with the slider bar set to better battery. Any help would be appreciated.  thanks
2021-08-25T15:45:27+00:00
Hi All,
I too was fed up with this issue getting nowhere online.
I created a short script that will change req items to allow for advanced options to be displayed.
$sting77 = "HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings"<br><br>$querylist =  reg query $sting77<br><br>foreach ($regfolder in $querylist){<br><br>    <br><br>    $active = $regfolder -replace "HKEY_LOCAL_MACHINE" , "HKLM:"<br><br>    <br><br>    Get-ItemProperty -Path $active<br><br>    Set-ItemProperty -Path "$active" -Name "Attributes" -Value '2'<br><br>    <br><br>    }
Run this in an Elevated Powershell ISE and it should fix it straight away as mine are now showing:
56 additional answers
    2021-04-15T10:43:38+00:00
    Hi
    I did a clean install of windows. No manufacturer or 3rd party apps and drivers. Its a pain but it worked for me. I added back drivers only as needed either directly from Intel or AMD. Ditched almost all HP drivers except were absolutely necessary. Also update your BIOS and Chipset firmware.
    Regards
    Gary
    2021-04-15T10:39:21+00:00
    Hi
    If its running that hot it might be a hardware problem. If its still under warranty I would contact Dell support.  I have found most of the 3rd party apps do not work for this. I'm not familiar with the Dell motherboards but there could also be a setting in the BIOS that could help. Also check to see if Windows Security
    and Windows Indexing are running out of control ( ctl-alt-del, task manger, look under process) both of these have been culprits in the past.
    I fixed my issue by doing a clean reinstall of windows, no manufacturer or 3rd party drivers or applications. Then added back drivers and apps as needed.
    But i think you might have a hardware problem so call Dell. They should be able to help.....hopefully.
    Regards
    Gary
    2021-04-11T16:03:33+00:00
    I have tried all the available information to try to restore the power options.
    using
    powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61
    powercfg -setactive e9a42b02-d5df-448d-aa00-03f14749eb61
    etc.
    I got the High Performance plan to show up for 2 minutes and then it disappeared.
    For me I need the USB options as I have monitors powered thru USB connection and they always have to reconnect every time my computer wakes.  When the USB monitor shuts down, all of the active app windows move back to the main monitor.  So I have to wait for the monitor to connect and then move all the app windows back to where they were...very annoying
    2021-03-12T09:27:57+00:00
    Hey, did you got any solution.
