We can't create a recovery drive when trying to create a NEW recovery drive.
2023-03-23T20:01:10+00:00
When I created my recovery drive the only drive available with the necessary space available was a removable hard drive. I ordered a new flash drive that was big enough and today I tried to create a new recovery drive.
App comes up no problem but after checking my system for available drives it returns the error
"We can't create the recovery drive" A problem occurred while creating the recovery drive.
I checked the forum for help and saw a reference to regagentc /info so I ran it and compared to the one posted mine actually had a drive listed. I disconnected the drive and restarted the system; but got the same error and information.
So basically, how can I create a new recovery drive? How would anyone create a new one if say their old one became unusable? There must be some information somewhere.
Thanks in advance,
Pamela
Windows for home | Windows 11 | Recovery and backup
2023-03-23T21:01:01+00:00
Hi, MissPam_Samm,
Sorry to hear you're experiencing this issue.
This error is usually related to the option "Back up system files to the recovery drive", sometimes creating the recovery drive with this option unchecked first and then recreating with this option checked may fix the problem.
1-Click on Start, search for the recovery drive, and click on that
2-In the Recovery Drive wizard uncheck the "Back up system files to the recovery drive" option
3-Click on Next
4-Select the USB drive that you intend to use as a recovery drive
5-Click Next to continue
6-Click the Create button to confirm the action. The utility will format the drive and copy the required files to the storage device
7-Regardless of whether you see an error or the process completes successfully, don’t click the Finish or Close button
8-Instead, click on the back button in the upper left corner
9-Now check the option "Back up system files to the recovery drive"
10-Then click on Next and follow the instructions to create the recovery drive
48 additional answers
    2024-01-16T04:51:11+00:00
    Thanks for the reply but I tried all that and it didn’t work. The “next” button was grayed out on the screen telling me to use at least a 32 GB flash drive. So can’t proceed.
    2024-01-18T23:08:14+00:00
    How do I close this question out?
    2024-01-29T13:57:49+00:00
    Use at least 64GB flashdrive (disk space consumed will leave you just 15.3 GB free space... don't know what happened but total disk size after the process is 31.9GB, 16.6GB used and 15.3 free...which is supposed to be 57GB usable space for a 64GB flashdrive...perhaps the rest are system files and are hidden)
    Disable windows defender or other antivirus protection. Then proceed creating the recovery drive. Worked for my Windows 11. Kindly give a feedback if it also works for you.
    Hope this helps.
    2024-01-31T08:17:12+00:00
    Thanks, but this didn't work either. Same problem....
