Kernel Power 41 code 63, help please.
2023-03-18T23:38:37+00:00
Most recently, I ran into a problem, namely, that during the game my computer freezes tightly. After looking at the action log, I found there critical errors Kernel Power 41 with code 63. I tried everything, and reinstalled Windows, and checked the RAM for errors, and everything like that, nothing helped. Through the sfc /scannow command, 4 corrupted files were found, they were installed, but the error still remained. Please, please help me!
    2023-03-19T22:17:02+00:00
    The tuneup plus results were unable to be translated using google translate.
    It kept detecting different languages.
    Please comment on each steps #2 and #3.
    2023-03-19T20:52:02+00:00
    1. When available please post the results of this script:
    (make sure that it is a new run of the script)
    https://www.elevenforum.com/attachments/tuneup_plus_log-bat.36285/
    1. When possible please run the computer in safe mode overnight while sleeping.
    The longer the continuous run the better the testing conditions.
    If there is a new BSOD overnight then run the V2 share link while in safe mode and post a share link into the newest post using one drive, drop box, or google drive.
    1. If your comfortable inside this Z490-A PRO (MS-7C75) computer then find components for swap testing.
    While finding components you can run software stress tests.
    More often the software stress tests fail to identify the malfunctioning component so swap testing is typically required.
    Alternatively the computer can be tested at a local computer store.
    Indicate the components that you have available or can borrow for swap testing.
    Start with the CPU and if available plan to test the motherboard.
    Event[2282]:
    Log Name: System
    Source: Microsoft-Windows-WHEA-Logger
    Date: 2023-03-19T01:10:09.2230000Z
    Event ID: 18
    Task: N/A
    Level: ╬°шсър
    Opcode: ╤тхфхэш
    Keyword: N/A
    User: S-1-5-19
    User Name: *removed PII*
    Computer: *removed PII*
    Description:
    ╧Ёюшчю°ыр эхєёЄЁрэшьр  ряярЁрЄэр  ю°шсър.
    ╤ююс∙шт°шщ ъюьяюэхэЄ:  фЁю яЁюЎхёёюЁр
    ╚ёЄюўэшъ ю°шсъш: Machine Check Exception
    ╥шя ю°шсъш: Internal Timer Error
    ╚─ APIC яЁюЎхёёюЁр: 1
    ─юяюыэшЄхы№э√х ётхфхэш  ёюфхЁцрЄё  т яюфЁюсэюёЄ ї ¤Єющ чряшёш.
    Event[1641]:
    Log Name: System
    Date: 2023-03-18T05:05:03.6970000Z
    Event ID: 18
    Task: N/A
    Level: ╬°шсър
    Opcode: ╤тхфхэш
    Keyword: N/A
    User: S-1-5-19
    Description:
    https://1drv.ms/u/s!AhQhQCapuHE4ccxcoxC4emyGP5I?e=CDlQbw
    sorry, here is the new data from the test.
    2023-03-19T20:32:15+00:00
    Event[2282]:
    Log Name: System
    Event ID: 18
    Task: N/A
    Level: ╬°шсър
    Opcode: ╤тхфхэш
    Keyword: N/A
    User: S-1-5-19
    Description:
    Event[1641]:
    Log Name: System
    Event ID: 18
    Task: N/A
    Level: ╬°шсър
    Opcode: ╤тхфхэш
    Keyword: N/A
    User: S-1-5-19
    Description:
    2023-03-19T18:09:44+00:00
    Hello. Removed the antivirus, but still got a blue screen when using the game Warzone 2.0 with an error whea uncorrectable error
    2023-03-19T18:08:54+00:00
    https://1drv.ms/u/s!AhQhQCapuHE4cJDGg3n5-WfudEs?e=cTmQDmAbout 10 minutes ago the blue screen reappeared..
