Intel Pro Set Wireless
2023-03-03T13:14:02+00:00
Do the windows updates include all driver updates including the Intel Drivers?
I noticed that there are several updates for intel drivers like this one for example the Intel Pro Set Wireless.
Should I do the update or will this make problems with my wireless connection?
Kenneth
  1. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-04T12:25:02+00:00
    Hi Kenneth,
    Uninstalling the Optane Pinning should be enough.
    2023-03-04T12:47:08+00:00
    I went through that procedure and I get the following message!
    The feature that you are trying to use is on a network resource that is unavailable.
    Kenneth
  3. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-04T12:57:18+00:00
    Hi Kenneth,
    Did you follow the steps on that link I provided on the intel website?
    2023-03-04T13:26:20+00:00
    Exactly to a t. I went to the Intell Optane Pinning Explorer Extension and right clicked and then clicked repair and that is when I received the message that I provided to you.
    Kenneth
  5. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-04T13:29:08+00:00
    Hi Kenneth,
    Did you download and install the version of Intel RST drivers recommended on the support page for your PC on the manufacturers website?
