Intel Pro Set Wireless
2023-03-03T13:14:02+00:00
Do the windows updates include all driver updates including the Intel Drivers?
I noticed that there are several updates for intel drivers like this one for example the Intel Pro Set Wireless.
Should I do the update or will this make problems with my wireless connection?
Kenneth
    2023-03-03T23:23:10+00:00
    I cannot get rid of the stupid Intel Optane Memory pop-up.
    Can the Intel Optane Memory area of the app be deleted or is Intel a part of the Graphics as the pop-up keeps coming back?
    Kenneth
  2. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-04T08:05:36+00:00
    Hi Kenneth,
    Sorry, I was offline.
    Is the popup you are seeing about Intel Optane, the one in this article?
    https://www.intel.com/content/www/us/en/support...
    ________________________________________________________
    Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2023-03-04T11:51:02+00:00
    I did a reset of Windows and what a nightmare as my computer became as slow as back in the 40's.
    The issue from what I can see was the Microsoft One Drive which as is a hog for taking up memory so I sent it to the uninstall ben.
    As to the Intel Optane Memory pop-up it is gone and hopefully for good however if I uninstall the driver will it affect any part of the operating system such as graphics?
    Kenneth
  4. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-04T11:52:46+00:00
    Hi Kenneth,
    Rest assured uninstalling that driver will not have any bad affect on your PC or Windows installation, including your graphics.
    2023-03-04T12:12:31+00:00
    Just to make sure I have this correct will I be uninstalling the complete Intel Optane driver program or just uninstalling the Optane Pinning?
    Thanks in advance,
    Kenneth
