Intel Pro Set Wireless
2023-03-03T13:14:02+00:00
Do the windows updates include all driver updates including the Intel Drivers?
I noticed that there are several updates for intel drivers like this one for example the Intel Pro Set Wireless.
Should I do the update or will this make problems with my wireless connection?
Kenneth
  1. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-03T15:19:12+00:00
    Hi Kenneth,
    It is possible the drivers can cause problems with your WiFi connection, that is why I advise not to install them.
    2023-03-03T16:49:20+00:00
    I canceled the process. On another issue, I am now getting a notice that Lightshot failed to register a hotkey, and some other program is already using it.
    How do I find out what other program? is taking over that feature?
    Kenneth
  3. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-03T16:53:09+00:00
    Hi Kenneth,
    That is really not my area, but I will try to find out for you, what keyboard shortcut will not work in Lightshot and is there no way to assign that keyboard shortcut to another combination in Lightshot settings?
    2023-03-03T17:07:10+00:00
    As to the Intel Optane Memory pop-up I went to the hidden programs on the taskbar and quit the program.
    Hopefully, that will work as I do not want to throw this thing out in the snowbank LOL
    Kenneth
  5. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-03T17:15:55+00:00
    Hi Kenneth, glad to help!
