Intel Pro Set Wireless
2023-03-03T13:14:02+00:00
Do the windows updates include all driver updates including the Intel Drivers?
I noticed that there are several updates for intel drivers like this one for example the Intel Pro Set Wireless.
Should I do the update or will this make problems with my wireless connection?
Kenneth
  1. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2023-03-03T14:32:39+00:00
    You should use Intel® Driver & Support Assistant for downloading correct wifi device drivers from intel website.
    2023-03-03T14:43:07+00:00
    As you state (Should) however I come back to my question why did I see updates for those drivers?
    It appears to me that the windows updates are not picking up the updates from Intel and on that subject, I myself usually have to go and check for updates as I do not get a notice for updates.
    Kenneth
    2023-03-03T14:52:39+00:00
    That is where I saw the notice for updates.
    I did however click for the updates however the download is just scrolling and seems to be not updating.
    Kenneth
  4. DaveM121 933.9K Reputation points Independent Advisor
    2023-03-03T14:54:32+00:00
    Hi Kenneth,
    Windows automatically checks your hardware and tries to install the latest driver updates, it is a personal choice if you want to install them, I never install them because I have seen too many people having problems after doing that, but it is a personal choice if you do want to install them.
    2023-03-03T15:14:56+00:00
    I agree with that and also I notice it states that it will download a driver package and my concern is will this just frig up my WIFI connection where I would need someone from my service provider to adjust things with a bill attached to it?
    Kenneth
