Hi Kenneth,
Sorry, I was offline, yes, those steps should work to enable Intel Optane.
Do the windows updates include all driver updates including the Intel Drivers?
I noticed that there are several updates for intel drivers like this one for example the Intel Pro Set Wireless.
Should I do the update or will this make problems with my wireless connection?
Kenneth
Hi Kenneth,
Does this mean that I do not have the disk for Intel Optane Memory as in concern to what is stated below?
Your System is not Intel Optane ready
No compatible disks for Intel Optane Memory
Is there a particular serial number of the Intel drivers that will be needed for my computer?
Kenneth
Hi Kenneth,
That is correct, the model numbers of your drives indicate that do not have Intel Optane
Was Microsoft sending me updates for the Intel Optane Memory?
Kenneth
