dual EFI entries after GPT conversion
2023-02-18T01:49:50+00:00
For reasons too lengthy to detail here, I was unable to use MBR2GPT for converting my current boot disk. Instead, I used Hasleo Disk Clone to clone the disk to another SSD while also converting it to GPT. This worked fine and the new drive correctly shows up as GPT with the shiny new MSR and EFI partitions. However, it left the protected/system EFI directory intact on the drive. My UEFI has been set to UEFI only with CSM=Disabled and yet I can still see entries for both EFI instances. Booting to the GPT partition works fine, but booting to the EFI directory fails. Is it possible (and safe) to either archive/rename or delete the EFI directory on C:\ so that it is no longer detected by the UEFI and disappears from the boot menu? I'm loathe to take any of the additional steps towards a Win11 upgrade without sorting this out first.
2023-03-07T05:38:10+00:00
(1) Even looking at the log, I'm unsure what's up with /SetREImage. But I think it is unnecessary. We'll revisit it if necessary.
(2) It looks like /Disable followed by /Enable would get the job done all by themselves. /Disable moved WinRE.wim from partition 3 into the staging area, namely C:\Windows\system32\Recovery....
2023-03-06 17:24:41, Info [ReAgentc.exe] winreCopyWIMBack moved WIM file from \?\GLOBALROOT\device\harddisk3\partition3\Recovery\WindowsRE\ to C:\Windows\system32\Recovery\Winre.wim successfully!
Then /Enable wanted to move it into partition 4, which it did recognize to be the Recovery partition. But it found that partition to be too small...
2023-03-06 17:24:49, Info [ReAgentc.exe] Checking partition at offset 497942528000, partition number: 4
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements Partition details: {Offset: 497942528000, Free space: 467849216, Total space: 487256064}
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements WinRE WIM size: 423565200
2023-03-06 17:24:49, Info [ReAgentc.exe] MeetPartitionRequirements Required free space: 478091152
2023-03-06 17:24:49, Warning [ReAgentc.exe] MeetPartitionRequirements Not enough free space req = 478091152 avail = 467849216 offset = 497942528000
2023-03-06 17:24:49, Info [ReAgentc.exe] skip partition because it does not meet WinRE requirements
(3) So, let's make it bigger. Mine is 848 MB. Your Disk Management (DM) shows the Recovery partition of 465 MB is followed by 1.56 GB of unallocated space...
Unfortunately, DM won't let you make it larger because it is a system partition. Can you easily add 383 MB to it using AOMEI Partition Assistant? If not, we can try this...
DiskPart <<<Enter DiskPart
Select Disk 3 <<<Focus on the EVO 970
List Part <<<Show its partitions
Select Part 4 <<<Focus on its Recovery partition
Detail Part <<<Show it has the Recovery type code
SET ID=ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 Override <<<Basic Data Partition
Detail Part <<<Show the new type code
Exit <<<Leave DiskPart
The 2nd Detail Part should show the new type. It is now a Basic Data Partition. Reboot to be sure the whole system knows. Then open Disk Management, right-click what was the Recovery partition, & see whether you can extend volume to 848 MB. Then make it a Recovery partition again this way...
Select Part 4 <<<Focus on what was its Recovery partition
Detail Part <<<Show it has the Basic type code
SET ID=de94bba4-06d1-4d40-a16a-bfd50179d6ac Override <<<Recovery Partition
I would Reboot again. Then, try...
ReagentC /Disable
ReagentC /Enable
ReagentC /Info
I hope that will do it. Good luck.
2023-02-23T12:27:49+00:00
(1) This should move {bootmgr} back to the top of DisplayOrder...
BCDEdit /Set {FWBootMGR} DisplayOrder {BootMGR} /Addfirst
That is where it belongs. I don't know how it got to the bottom. Do a full reboot for it to register in BIOS. Then, show us a new BCDEdit /Enum All.
That's nasty that BIOS adds one back after you have deleted it.
(2) The order of the GUIDs in DisplayOrder does not have to be the same as they are in the body of the BCD. In the body, they are in the order the boot entry was created. Moving one to the top of DisplayOrder should also move it to the top in BIOS Setup (after a full reboot). It then becomes the one that will boot by default. That is, it's the one that boots unless you chose another by using the one-time BIOS Boot Options menu. I think in your Asrock that is invoked with F11. (And DEL or F2 goes to BIOS Setup).
(3) I'm confused about your BIOS. I don't have one that complex.
(a) I don't know why it's got 4 Boot Options.
(b) Are you sure it is Boot Option #1 that is executing? Maybe disable ...#2 to be sure.
(c) Show us the contents of ...#2 as you showed ...#1 below.
(d) What is that item that is disabled within ...#1?
Our goal is to have you boot to the EVO that has Windows on it. So, that is the drive that needs to be at the top of the Boot Order in your Boot Option #1. Is it...?...
The way to know that it is the correct Windows partition that is booted is that your C: partition will be 463 GB...
Ramesh 181.8K Reputation points Volunteer Moderator
2023-02-23T03:26:03+00:00
Rebuilding the BCD should be enough, not the entire boot files, even though rebuilding the entire boot files doesn't do any harm.
And wondering why you're trying to create a Recovery drive with system files? Is it for backup/restore purposes or only for accessing WinRE? If it's for accessing WinRE, you can uncheck "Backup system files..." and create the media.
Regarding your question about C:\EFI folder, you can simply rename it. If Windows reboots correctly, that folder can be deleted. Do this only after creating the USB setup disk or Recovery drive.
56 additional answers
    2023-03-01T02:16:43+00:00
    (1)
    (a) As I said earlier, the Volume numbers in Disk Part (List Vol) are not related to the HarddiskVolume numbers in the BCD. Volumes are partitions that have a file system. I'm unsure in what order they are enumerated. I guess it was the order in which they were created at least at first. But those aren't mentioned in the BCD.
    (b) ResumeObject brings Windows out of a sleep &/or a hibernation (I guess). It is the Windows Recovery Environment entry in the BCD that must be changed to point to the 4th partition on Disk 3 (HarddiskVolume8) instead of to C:.
    In ReagentC, it will be called "Harddisk3\Partition4".
    In the BCD, it will currently be called HarddiskVolume8. (It self-adjusts to your partition doings).
    (2) Your BCD says HarddiskVolume6 holds the boot manager (BOOTMGFW.EFI) which was used for this boot to Windows. So that is your EFI partition...
    Windows Boot Manager
    identifier {bootmgr}
    device partition=\Device*HarddiskVolume6* <<<EFI
    path \EFI\MICROSOFT\BOOT\BOOTMGFW.EFI
    It's counting partitions from Disk 0 through Disk 3 to arrive at ...6. You must have put a partition back onto Disk 2...
    Disk 0: 2 partitions...
    DISKPART> sel dis 0
    DISKPART> lis par
    Partition ### Type Size Offset
    Partition 1 Reserved 15 MB 17 KB
    Partition 2 Primary 232 GB 16 MB
    Disk 1: 1 partition...
    DISKPART> sel dis 1
    DISKPART> lis par
    Partition 1 Primary 1863 GB 1024 KB
    Disk 2: 1 partition now (used to be 5 partitions, then 0).
    Disk 3: 4 partitions...
    DISKPART> sel dis 3
    DISKPART> lis par
    Partition 1 Reserved 128 MB 1024 KB <<<MSR
    Partition 2 System 100 MB 129 MB <<<EFI (2nd partition of Disk 3)
    Partition 3 Primary **** 463 GB 229 MB <<<Windows
    Partition 4 Recovery 464 MB 463 GB <<<Recovery (HarddiskVolume8)
    EFI is HarddiskVolume6. And Recovery is ...8. (I know I said ...4 earlier -- but it's ...8).
    (3) So, here are the commands to point the system to the Recovery partition. These are just 3 commands. Copy/paste them one at a time into an Admin Command Prompt...
    BCDEdit /Set {e1f8ff5c-b603-11ed-850b-a8a1594c6c15} Device Ramdisk=[\Device\HarddiskVolume8]\Recovery\WindowsRE\Winre.wim,{e1f8ff5d-b603-11ed-850b-a8a1594c6c15}
    BCDEdit /Set {e1f8ff5c-b603-11ed-850b-a8a1594c6c15} OSDevice Ramdisk=[\Device\HarddiskVolume8]\Recovery\WindowsRE\Winre.wim,{e1f8ff5d-b603-11ed-850b-a8a1594c6c15}
    BCDEdit /Set {e1f8ff5d-b603-11ed-850b-a8a1594c6c15} RamdiskSDIDevice partition=\Device\HarddiskVolume8
    Reboot after that. Then let's see a ReagentC /Info.
    That should do it! But afterward -- if all looks & works well -- we might consider deleting the WindowsRE folder from C:\Recovery. It would go like this...
    RD C:\Recovery\WindowsRE /S <<<Delete the extraneous WindowsRE folder
    2023-03-01T01:04:36+00:00
    Ummm... my brain hurts. Your example appears to show that your ResumeObject is the same as mine - C:\ partition. If that's good enough for an expert, surely it's good enough for me? Anyway, there's a disconnect with how ReagentC sees this in terms of the DiskPart terminology of dis3/par3 and how it's stored in the BCD as HDvolume6. That crosscheck makes me even more confused, but at least the GUID of the ResumeObject is consistent everywhere (except that final DeviceOption that's likely the USB key).
    DISKPART> lis vol
    Volume ### Ltr Label Fs Type Size Status Info
    Volume 0 D DVD-ROM 0 B No Media
    Volume 1 E DataDrive NTFS Partition 232 GB Healthy
    Volume 2 G Gaming NTFS Partition 1863 GB Healthy
    Volume 3 F DataDrive2 NTFS Partition 232 GB Healthy
    Volume 4 C NTFS Partition 463 GB Healthy Boot
    Volume 5 FAT32 Partition 100 MB Healthy System
    Volume 6 Recovery NTFS Partition 464 MB Healthy Hidden
    Volume 7 I Removable 0 B No Media
    Volume 8 J Removable 0 B No Media
    Volume 9 K Removable 0 B No Media
    DISKPART> lis par
    Partition 3 Primary 463 GB 229 MB
    C:\Windows\system32>reagentc /info
    Windows Recovery Environment (Windows RE) and system reset configuration
    Information:
    Windows RE status:         Enabled
    Windows RE location:       \\?\GLOBALROOT\device\**harddisk3\partition3**\Recovery\WindowsRE
    Boot Configuration Data (BCD) identifier: e1f8ff5c-b603-11ed-850b-a8a1594c6c15
    Recovery image location:
    Recovery image index:      0
    Custom image location:
    Custom image index:        0
    REAGENTC.EXE: Operation Successful.
    Microsoft Windows [Version 10.0.19045.2604]
    (c) Microsoft Corporation. All rights reserved.
    C:\Windows\system32>bcdedit /enum all
    Firmware Boot Manager
    identifier {fwbootmgr}
    displayorder {bootmgr}
    timeout 3
    device partition=\Device\HarddiskVolume6
    description Windows Boot Manager
    locale en_US
    inherit {globalsettings}
    flightsigning Yes
    default {bootmgr}
    resumeobject {8aa54c62-2e50-11e3-a87c-d9faf047cf21}
    displayorder {current}
    toolsdisplayorder {memdiag}
    timeout 2
    Windows Boot Loader
    identifier {current}
    device partition=C:
    path \Windows\system32\winload.efi
    description Windows 10 Home
    locale en_US
    inherit {bootloadersettings}
    recoverysequence {e1f8ff5c-b603-11ed-850b-a8a1594c6c15}
    displaymessageoverride StartupRepair
    recoveryenabled Yes
    isolatedcontext Yes
    flightsigning Yes
    allowedinmemorysettings 0x15000075
    osdevice partition=C:
    systemroot \Windows
    nx OptIn
    bootmenupolicy Standard
    Windows Boot Loader
    identifier {a2a20109-981b-4aa1-abb7-3c015278072a}
    device ramdisk=[C:]\Aomei\AomeiBoot.wim,{68c7d26e-b6a2-4d56-9184-ef9dcb9e3ee5}
    description Aomei PE
    osdevice ramdisk=[C:]\Aomei\AomeiBoot.wim,{68c7d26e-b6a2-4d56-9184-ef9dcb9e3ee5}
    systemroot \Windows
    detecthal Yes
    winpe Yes
    Windows Boot Loader
    identifier {e1f8ff5c-b603-11ed-850b-a8a1594c6c15}
    device ramdisk=[C:]\Recovery\WindowsRE\Winre.wim,{e1f8ff5d-b603-11ed-850b-a8a1594c6c15}
    path \windows\system32\winload.efi
    description Windows Recovery Environment
    locale en_US
    displaymessage Recovery
    osdevice ramdisk=[C:]\Recovery\WindowsRE\Winre.wim,{e1f8ff5d-b603-11ed-850b-a8a1594c6c15}
    systemroot \windows
    nx OptIn
    winpe Yes
    Resume from Hibernate
    identifier {8aa54c62-2e50-11e3-a87c-d9faf047cf21}
    device partition=C:
    path \Windows\system32\winresume.efi
    description Windows Resume Application
    locale en_US
    inherit {resumeloadersettings}
    recoveryenabled Yes
    isolatedcontext Yes
    filedevice partition=C:
    filepath \hiberfil.sys
    pae Yes
    debugoptionenabled No
    Windows Memory Tester
    identifier {memdiag}
    path \EFI\Microsoft\Boot\memtest.efi
    description Windows Memory Diagnostic
    locale en_US
    badmemoryaccess Yes
    EMS Settings
    identifier {emssettings}
    bootems No
    Debugger Settings
    identifier {dbgsettings}
    debugtype Serial
    debugport 1
    baudrate 115200
    RAM Defects
    identifier {badmemory}
    Global Settings
    identifier {globalsettings}
    inherit {dbgsettings}
                        {emssettings}
                        {badmemory}
    Boot Loader Settings
    identifier {bootloadersettings}
                        {hypervisorsettings}
    Hypervisor Settings
    identifier {hypervisorsettings}
    hypervisordebugtype Serial
    hypervisordebugport 1
    hypervisorbaudrate 115200
    Resume Loader Settings
    identifier {resumeloadersettings}
    Device options
    identifier {68c7d26e-b6a2-4d56-9184-ef9dcb9e3ee5}
    ramdisksdidevice partition=C:
    ramdisksdipath \Aomei\AomeiBoot.sdi
    Device options
    identifier {e1f8ff5d-b603-11ed-850b-a8a1594c6c15}
    ramdisksdipath \Recovery\WindowsRE\boot.sdi
